Anyone use this pulley for a SC upgrade?
Old Jul 26, 2023 | 01:11 PM
Staatsof's Avatar
Default Anyone use this pulley for a SC upgrade?
Now that I finally have a commitment from a local Jag service shop to fix my 2005 STR and we have the parts sourced locally from the dealer, I'm thinking of changing the top SC pulley.
https://www.ebay.com/itm/122536104037
It's a high strength steel that's powder.coated so the materials look good. This isn't rocket science and I'll have the techs validate it before it's installed. Heat it up to 400F and slip in on quickly.
Since they'll have the SC off I thought I might as well let them do it.
Old Jul 26, 2023 | 02:44 PM
clubairth1's Avatar
Community Influencer
With the long time problems you have so far with your STR. I think I would get it fixed up stock before adding anything?
Your car and your choice.
Old Jul 27, 2023 | 10:37 AM
scottjh9's Avatar
I have that one on my charger. I used a toaster oven to heat it up. 425 for 45 mins. Since the charger will be off you could remove the front section and use a press. Then you get every drop of oil out
Old Jul 27, 2023 | 11:27 AM
Staatsof's Avatar
I'm going for it!
Every GD hose and gasket is getting replaced. The only thing I'm not replacing is the coolant reservoir tank because I've had 3 of them and everyone of them weeps coolant, nothing serious though. Jag just had crappy tanks made. So why bother?
Car goes to the shop on Mon. or Tue.
Old Jul 27, 2023 | 11:36 AM
Staatsof's Avatar
That's how I've done similar pulleys and drives on my other cars. It works just fine.My mechanic used to work at Jaguar headquarters in NJ in the service training department before Tata motors bought them out so he knows what he's doing with these cars.
Old Jul 27, 2023 | 04:40 PM
scottjh9's Avatar
perfect. Hope you get to driving it soon
Old Jul 28, 2023 | 01:16 PM
Staatsof's Avatar
If all goes well in about a week or two. We need to be careful since the car has been sitting for almost 4 years. Once he gets the engine running well he'll get the rotors cleaned up, flush the brake fluid and then I have to order new tires. It's going to run about $7-8 K and a huge chunk of that is parts
Fingers crossed.
RochaSDS
Mar 27, 2023 05:28 AM
Etip
May 16, 2017 06:57 AM
Taino
Dec 2, 2016 03:43 PM
vincent661983
Jun 4, 2012 03:08 PM
