Anyone used Chipexpress in their 2.7D?
Hi, first post in the big boys bit of the forum.
I have a 2.7D Auto and have been looking at Chipexpress because of the easy installation and removal, and the lack of daft claims. Also, £395 seems reasonable for someone NOT to be monkeying around with the ECU on a permanent basis.
Anyone used one, and what happened when/if you wound it up to 275BHP?
Detail here.
Jaguar S-Type 2.7D 207 PS 435 Nm | Diesel Tuning with CHIP Express™
They do make a lot of claims.....
Are these borne out by experience?
Have you had a remap done, and what did it do for fual consumption?
Detail here.
- User-adjustable for up to 40% more power and torque, 20% more economy
- Unlocks your vehicle's full potential using TUV certified, tested software
- CE approved with ISO 9001 quality assured chipset technology
- Simple 20 minute or less "plug-in" installation - no wires to cut
- Can be removed without trace in minutes
- Pre-programmed for your specific vehicle, no complex setting up
- Unlike a remap our systems cannot be detected or deleted during routine servicing
- Does not require the removal of your vehicle's original programme settings
- Superior performance on demand whilst keeping the engine standard at idle
- Eliminates flat spots, reduces turbo lag and sharpens throttle for a smoother drive
- Select higher gears sooner, change down less, reduce revs - better economy
- Use less throttle for similar driving conditions, further reducing consumption
- Makes more of the RPM range usable, for safer overtaking
- Compliant with vehicle emission standards, suitable for diesel particulate vehicles
- Suitable for manual or automatic vehicles
- Will not invalidate your vehicle warranty
- Produces more low down torque compared to a remap - helps towing
- Comes with full photographic guide for your vehicles engine
- Full 3 year warranty for your peace of mind
- "No quibble" refund within 14 days if you are not 100% delighted
Not had a jag done but have had others remapped and found an increase in power at lower revs, fuel consumption stayed about the same.
I had them remapped (not a plug in tuning box)
This looks to do the same (increase fuel rail pressure) but cheaper.
Tuning-diesels Synergy 2 shop.
Post back how you get on
Hey there,
I can't honestly say about the tuning box setups.
There saeem to be some good reviews around for them and some not so good......I'm not really 100% sure why but I've always stayed away from them.
I've had several cars remapped professionally, by Saab UK, Seditas of Ayr and Stirling Audi.
Generally they have run about £400, approx double that if going with the OEM on a brand new car.
You can expect to see around 25% - 30% increase in bhp and also added torque. When on a long run and driven normally, you can expect to get around 10% - 15% fuel economy savings to boot, so if you do long distances or lots of miles there is a payback to it.
Hope it helps
Probably a poor choice, but check on the UK forum because there are no diesel jags in USA/Canada etc so you're going to get very few comments from 2.7D jag owners here.
The diesel jag has a whole bunch of potential problems unique to it so it's a bit brave to mess with it... I sure hope you don't have one with a DPF!
Have a look here https://www.jaguarforums.com/forum/s...-2005-a-10010/
Last week I fitted a chip express to my 2.7 diesel XF Jaguar. It took about 15 minutes and the first drive showed much better response, smoother changes and better torque. I have also monitored the fuel consumption and this has dropped and I frequently get 6.5 L/100kms from highway driving. The chip arrived in NZ from the UK in 10 days and the company lived up to all its claims.
Regards
David
Regards
David
stanjag
Dec 29, 2024 08:26 PM
jaguarfanman
Jul 7, 2015 02:20 PM
