autobox selection problem 2000 s type
Old Mar 18, 2009 | 03:49 PM
mrjazon's Avatar
Default autobox selection problem 2000 s type
hi guys
got myself a 2000 s type.
having a problem with the auto box,the gears are fine but selection stick is the problem ill try explain
sometimes i try to start the car in P and no go move it to N starts ok
this is not all the time i might add,i have also noticed that when i go into P the reverse lights stay on but again not all the time if i move the selection lever down and up into P reverse lightgo off and i can then start the car from P its as if the box thinks its in R when infact its in P as when its in p somtimes it has the red indicator in R position i have never seen the red light in p is there anyway i can fix this problem myself an ajustment maybe
as im anewbie here i hope ive posted this in the right place
thanks
jason
Old Mar 18, 2009 | 09:46 PM
BHD2786's Avatar
sounds like your shifter cable is strecthed....
you can try and adjust it.....If you take off the center console top. there are 2 jam nuts on the side of the shifter you can adjust those and see if u can make it better...if not the cable must be replace...dont worry its not a big job
if this continues to happen there are some internal tranny modifications that need to be done...but before i went that far i would try a cable
stanjag
Dec 29, 2024 08:26 PM
MJ'S Jag
Nov 10, 2022 08:14 AM
jdzubas
Oct 4, 2015 09:14 AM
nelsonht
Aug 30, 2015 06:01 AM
peterg19
Aug 28, 2015 08:42 AM
