AutoLamps on 05 STR
Old Jan 27, 2010 | 10:22 AM
05STR's Avatar
Default AutoLamps on 05 STR
Strange problems when turning Left.
Seems like everytime I turn on my Left turn signal I get a Autolamps 2:00 / :30 / :10 message on my message center.
Anyone ever see this problem ?
I'm thinking it may need a replacment turn signal bar ?
Old Jan 27, 2010 | 11:54 AM
JOsworth's Avatar
Yikes.... Since the headlamp switch and turnsignal are on the same stalk that would be the first thing I checked / replaced. Is the sequence of the messages exactly what you are seeing? I ask since that is the sequence the switch takes as you move up from the lowest position through the auto lamp settings.... Weird... It's like it is cycling the switch through the flasher... Are the messages showing in time with the flasher?
Old Jan 27, 2010 | 12:26 PM
05STR's Avatar
Tes the 1st time is press the bar it would go 2:00 next time :30 next time after that :10 and then to off.
I still am under the Select warrenty hope they fix it.
Old Jan 27, 2010 | 04:08 PM
JOsworth's Avatar
I'd be pretty sure they will. It covers faulty electrical components. Make sure you can easily replicate the issue and show the service writer exactly what it is doing.
Old Jan 27, 2010 | 10:12 PM
Real_Tech's Avatar
Default It's covered
Never seen one that wasn't the switch. It is covered by select edition warranty.
Old Jan 28, 2010 | 08:15 AM
Jon89's Avatar
Real Tech,
A hearty welcome back, and I sincerely hope you'll become a regular again. Your outstanding advice and contributions have been sorely missed by several of us here....
Old Jan 28, 2010 | 10:53 AM
Real_Tech's Avatar
Default Absence
My dealer principle bought an absolutely huge Ford store in Florida and I was spending time there helping with the change over and was way too busy for anything else. I'm back home now so I should be able to spend some more time on the forums.
clubairth1
30
Sep 3, 2025 04:38 PM
Manjag
Oct 1, 2015 05:34 PM
JaguarSV8
Oct 1, 2015 01:58 AM
SoCalJagS
Sep 27, 2015 09:20 AM
