Ball joints popped out?
Old Jun 5, 2020 | 08:44 PM
JagSTRRR's Avatar
Default Ball joints popped out?
Hey guys,
I’m fixing up a 2005 Jag STR which had been sitting for several years. I just noticed that it appears that two rear ball joint type linkages are popped out on both sides at the rear. See photos. Are these ball joints? Any idea how to fix? Can I just hammer them back in with some grease?
Thanks in advance!
Driver side rear
Passenger side rear
Old Jun 6, 2020 | 02:38 AM
Datsports's Avatar
Technically it is a ball joint . Though it’s called a swaybar link .
I think hammering them on would be a rough repair .
especially when they are not expensive.
aftermarket at least wold be still better than leaving them worn .
try here
https://www.ebay.com/itm/K750340-Moog-Sway-Bar-Link-Rear-Passenger-Right-Side-New-RH-Hand-for-S-Type-XJ8/124115263984?epid=110263012&_trkparms=ispr%3D1&has h=item1ce5d8a1f0:gcgAAOSwtVpeafvQ
and here
https://www.ebay.com/itm/K750339-Moo...IAAOSwtzZeY~mp
Old Jun 6, 2020 | 06:36 AM
joycesjag's Avatar
Forum sponsors also carry replacements.
Old Jun 6, 2020 | 09:27 PM
abonano's Avatar
The looks more like sheared, rusty.
I would replace them and carefully look at all other suspension components.
Old Jun 6, 2020 | 09:44 PM
jya's Avatar
jya
+1 on looking at all other suspension components.
Not good 'workshop' practice trying to reuse those.
On a 15 year old car unless they have been recently changed you will likely find that the rear lower trailing arms have leaking hydra-mount bushes, and quite likely the front lower arms as well.
Also high possibility that all four upper wishbone ball joints have perished as well.
If you want maximum safety, performance and ride you need to address this.
Old Jun 15, 2020 | 11:21 AM
clubairth1's Avatar
Community Influencer
Lots of work to do on that one!!
Rusty as can be and will be a LOAD of fun to work on!
Goldlion
Jan 2, 2013 04:07 PM
monz87
Jun 10, 2012 07:44 PM
XJRJeff
Jan 22, 2012 05:04 PM
pezzonovante88
Sep 2, 2011 07:31 AM
trauch
Jun 17, 2011 07:41 PM
