BIG Problem with my S Type
Old Jul 1, 2007 | 09:04 AM
Envy337's Avatar
Default RE: BIG Problem with my S Type
The failsafe mode is the reason the performance is restricted.
You might have a coil issue, try to get a cheap scanner and get the codes.
Old Jul 4, 2007 | 08:32 PM
cap79's Avatar
i think u have tranny promblem, between 3-4 gear.
Old Jul 5, 2007 | 09:31 PM
cap79's Avatar
if u are a jag tech u should know that older stypes have shift solinoid
problems, like main problem, and remember the transmission module is inside the transmission. what else could it possibly be.
Old Jul 22, 2007 | 03:04 PM
cap79's Avatar
yes u can get it separatly, but u should scan it first like vizcarra44 said.
Old Jul 23, 2007 | 08:12 AM
jag_genius's Avatar
actually older stype don't have module in trani... sounds like a coil issue check the codes..
Old Aug 8, 2007 | 05:26 PM
jag_genius's Avatar
half the time they don't give codes... if the do it can be like p0301 ,p0302.p0303 etc to 6 or 8 depending on the engibne size. misfire codes.
Old Aug 9, 2007 | 11:19 PM
YoungABS's Avatar
Sometimes I have the same issue...the code they gave me was P1385, some type of misfire...some ol' bs! I'm hoping it is a small thing and nothing serious.
stanjag
Dec 29, 2024 08:26 PM
RaceDiagnostics
Dec 11, 2015 10:12 AM
X_Type_South_Africa
Dec 9, 2015 05:37 PM
jdzubas
Oct 4, 2015 09:14 AM
johanasu
Sep 3, 2015 12:39 PM
