Boot Open- Trunk Ajar Warning Stays On! + Pretty Things?
Old Sep 26, 2017 | 06:26 AM
sunshinesdad's Avatar
Default Boot Open- Trunk Ajar Warning Stays On! + Pretty Things?
The warning stays on when boot//trunk us shut. I have checked that when I manually depress the switch, the light stays on.
I have read in these fora that it can be switch, or it can be "pinched" wiring somewhere, possibly in the loom near the right boot hinge.
See photos of switch, and the wires which feed it - one is black/white and one is black.
I used a multimeter to test the switch.
Using the "continuity" setting, it bleeped when the switch was pressed! I assume this means the switch was working ???
If so, where else should I look or test?
*Pretty things - see pic - when I opened the switch area top of boot, these pretty metal things fell out! One has a thin metal wire strip attached/
What are these? significant, or a present from the builders of the car?
Attached Thumbnails Boot Open- Trunk Ajar Warning Stays On! + Pretty Things?-jagboot4.jpg
Old Sep 26, 2017 | 07:11 AM
aholbro1's Avatar
Try giving the kidnap lanyard a yank or two, then shut the bootlid.
Old Sep 26, 2017 | 07:51 AM
Mikey's Avatar
Does your meter still show continuity when the switch is released? If yes, the switch is bad. If no, try bridging across the two terminal of the female side of the connector. If that doesn't turn off the light, suspect the wiring upstream.
Old Sep 26, 2017 | 08:35 AM
Default I found the problem!
Was broken wire in wiring loom right hand side of boot, under where the boot arm/support meets the car! - see pic!
Attached Thumbnails Boot Open- Trunk Ajar Warning Stays On! + Pretty Things?-brokenbootwarningwire.jpg
Old Oct 29, 2017 | 11:11 AM
klynn's Avatar
Where is your switch located. My trunk light does not come on and I don't get any warnings that it is open. I can't find the switch on my 98 XK8
Old Oct 30, 2017 | 03:11 AM
My switch (like a 1 inch long plastic covered button) is just to the right of centre of the boot lid, where the lock ring from the lid closes on the lock mechanism of the boot body.
My problem was broken wire in the loom under the right boot lid arm
Old Oct 31, 2017 | 08:45 AM
Mikey's Avatar
THe latest poster has a 98 XK8. not much point asking here.
