Brake Assembly for 2003 Stype R?
Old Jan 26, 2009 | 08:03 PM
chriss91's Avatar
Default Brake Assembly for 2003 Stype R?
Hey,
I recently purchased a 2003 stype R with 66,000 miles on it. It runs like a beast however the brakes are ridiculously squeaky. It sounds like the back brakes so my dad and I took off the tires to check the brakes and we were stopped with confusion. Is there reallytwo seperate disk brakes on the back? We looked in the manual and it says nothing about the brakes. Also I called Jaguar to see if I could purchase a shop manual but they say they don't have one. I would much rather change the brakes myself however I'm stunned at these complex brakes on the stype R. Does anyone have any advice pleassssse!!
Thanks Chris.
Old Jan 26, 2009 | 08:10 PM
Real_Tech's Avatar
Default RE: Brake Assembly for 2003 Stype R?
The R model with Brembo brakes has a seperate parking brake caliper because the Brembo calipers do not have parking brake capabilities. If you are changing the rotors you can either remove the park brake calipers or remove the 2 torx bolts that hold the 2 halves of the pb caliper together. If you are simply pad slapping(not recommended) you can change the pads without removing either caliper. Just make sure you hold the park brake apply button down when you turn the car off and the park brake wont automatically apply so you can get the caliper off or apart without any trouble.
Forcedair1
Sep 8, 2025 01:57 PM
neruda
Oct 18, 2015 01:19 PM
jdzubas
Oct 4, 2015 09:14 AM
kabs3012
Sep 12, 2015 10:40 AM
1964Daimler
Sep 9, 2015 11:28 AM
