Brake Booster Check Valve & Grommet
Old Jun 3, 2021 | 06:49 AM
cat_as_trophy's Avatar
Default Brake Booster Check Valve & Grommet
Greetings . . .
Thought I should pass this along, because it poleaxed me!
  • brake boost failure on our MY07 2.7L TTD;
  • removed check valve from vac booster, as grommet fell to pieces;
  • vac line uses engine driven pump (not manifold) with enough to pull elephant from bog!
  • toughest bit was finding how to unlock the "QuickConnect" fitting on the vac pump!
Decided to replace check valve as well as grommet - plenty on eBay for AU$50 and AU$15 but, armed with check valve I had cut off end of plastic line and measured hole in boost cylinder, went in search of my local country brake specialist . . . who tells me . . .
"Don't have much call for Jaguars mate, but the brake boost manufactures make both the check valves and grommets in only 2 sizes . . . older ones are BIG and newer ones are SMALL. Looks like you want a SMALL and the matching grommet,eh? Ten bucks all up!"
Once this kind chap (who I suspect is related to my guru mate Grant Francis) had dragged me up off the floor, he did alert me to a problem . . . I had cut off the old check valve, only to find it was probably OK, I was never going to get the barb of the new valve into that tube. Sure enough, no amount of heating helped. Again he supplied the solution . . . a short length of high pressure line that, with some effort, fitted over both the barb of new check valve and that hard plastic vac line.
Cheers,
JessN16
Aug 15, 2020 06:18 PM
yachtmanbuttson
Sep 12, 2019 07:43 PM
CaleyThistle
Apr 6, 2018 04:42 PM
drossy007
Dec 3, 2015 06:11 AM
verdugo
Oct 23, 2012 10:49 AM
