Brake booster vacuum line
Old Mar 14, 2009 | 08:01 AM
joycesjag's Avatar
Default Brake booster vacuum line
Ok fella's whats the trick to remove line from rear of intake manifold?
Upon futher inspection and O-ring replacement, is the oil in lower IMT sensor hole normal? If not what would cause that much oil in there? 2nd photo
Attached Thumbnails Brake booster vacuum line-intake.jpg   Brake booster vacuum line-intake-001.jpg
Old Mar 14, 2009 | 01:25 PM
mohrd's Avatar
To answer the first question, I believe you push down on the black collar, pull up on the line.
Second question you'll need a Tech to let you know how much (a trace probably) would be expected or acceptable.
Old Apr 7, 2012 | 02:53 PM
03JagSType3.0's Avatar
Sorry to kick up this very old post, but I am having the same question regarding the vacuum line.
What is the trick to remove the line? I am afraid to pull to much or hard that I would break the line. I looked at the reply and don't think it applies.
Old Apr 7, 2012 | 03:32 PM
Nevermind, I found this post that tells you how:
https://www.jaguarforums.com/forum/s...92/#post287688
clubairth1
30
Sep 3, 2025 04:38 PM
silkcat
Jan 18, 2025 04:29 AM
Bcrary3
Feb 21, 2023 04:29 AM
jdzubas
Oct 4, 2015 09:14 AM
explorer364
Sep 11, 2015 05:44 PM
