a/c blows hot - jag tech assistance would be great!!!
Old May 3, 2010 | 01:32 PM
justinb67's Avatar
Default a/c blows hot - jag tech assistance would be great!!!
I've got an 03 s-type with a/c blowing hot on all but one vent. Common problem from what I can gather. Here is what I've done.
Changed DCC Valve and Evap discharge sensor. blows hot anytime the engine is warm (even on *low*). Had the DCC Valve out before I bought one, and cycled it with 12v battery power, and one side did not seem to move completely, so that is what prompted the dcc valve change.
I have a JTIS CD for the card, so while had DCC Valve out the 2nd time, tested voltage/continuity to the fuse box it is good. Tested continuity from the two other pins to the pins going into the a/c module, they are good.
The contacts were a bit discolored going to the dcc valve, so I cleaned them with a small file so that they are clean and put it all back together.
Also when I had it apart, I had another person look at the dcc valve when powering on the car. Does the DCC Valve cycle when the car is turned on? Because one side cycled and the other did not.
I am suspecing the Climate Control Module now (perhaps a dcc valve failure broke the cc module?), since I would assume that both sides should cycle on power-up not just one... But wanted a 2nd opinion by a jag tech if possible.
Also, anyone know where you gan get these refurb'd? Tons of refurbishers on ebay for the older units (pre-2003), but I'm not seeing anyone fixing the 03-up units..
Thanks!
Justin
Old May 3, 2010 | 02:45 PM
Brutal's Avatar
Sounds like the ac board to me. There are test to determine but you need the wiring diag and dvom. Orrrrr just take out the module and open it. Youll see 1 or 2 burned marks right on top of the circuit board. Yep those are th eground circuit that short out when the ddcv cause a cross short within the solenoid housings. Just take it to someone that repairs circuit boards like a pc repair place and have them repair the circuits
Old May 3, 2010 | 10:18 PM
fordboy's Avatar
hey brutal i was curious where the a/c module was located.
Old May 3, 2010 | 10:38 PM
Brutal's Avatar
its the AC control panel, unless you have navigation. Then its on the side as a seperate unit on the side of the HVAC unit
Old May 3, 2010 | 11:28 PM
fordboy's Avatar
thanks.
Old May 4, 2010 | 07:50 PM
justinb67's Avatar
fantastic! Thanks for the response. If the damage is that visible I can probably fix it, I own a network consulting firm, and one of my friends used to fixe gaming equipment at C.E.C.. I will pull it apart this weekend and confirm the damage.
Justin
Old May 4, 2010 | 11:07 PM
Brutal's Avatar
HHmmm Maybe I should start repairing those too for $300 with exchange
Old May 5, 2010 | 08:56 AM
androulakis's Avatar
I thought the DCCV Blew up a couple transistors on the board when it went, and you had to desolder them and replace. It just burns out a ground trace? What's the fix? A Jumper wire between the now burned out trace?
(Once the offending DCCV has been replaced obviously)
George
Old May 9, 2010 | 04:36 PM
justinb67's Avatar
Brutal, you are awesome!!!
Yup it was a burnt ground trace, just jumpered it and put it all back together and it works!!!
I took pics, so I am going to post a how-to. or perhaps not and make it a side business on ebay LOL..
Justin
Old May 9, 2010 | 04:58 PM
justinb67's Avatar
how-to posted on the repair.
https://www.jaguarforums.com/forum/s...110#post202110
Old May 10, 2010 | 08:46 AM
Brutal's Avatar
youre welcome
fast40driver
Apr 19, 2024 07:24 AM
Stoney85
Jun 10, 2021 09:14 PM
Stoney85
Australia - Queensland
Jun 7, 2021 11:49 PM
Rupesh
Mar 25, 2016 03:33 PM
daro31
Sep 1, 2015 10:24 AM
