CEL Duration
Old Feb 16, 2011 | 12:25 PM
d33's Avatar
d33
Default CEL Duration
Hello All,
If your CEL comes on from loose gas cap, will it go off when corrected, or does it have to be reset.
I searched, and didnt find anything
Old Feb 16, 2011 | 12:54 PM
Jon89's Avatar
If the cause is indeed a loose gas cap, the CEL will typically go out on its own after a driving cycle or two once the issue is corrected....
Old Feb 16, 2011 | 12:55 PM
JagV8's Avatar
The site Search ignores short words
It'll go off. Should be after 2 or 3 cold-to-hot engine cycles. The code will remain stored internally for more cycles unless you clear it.
Old Feb 16, 2011 | 01:10 PM
tbird6's Avatar
Just went thru this on my 2005 STR. You can find the post if you search.
No the CEL will stay on until turned off. I had an emissions test done which includes a gas cap check off the vehicle. After getting a pass on the test the next day my car had a CEL. Got it checked and it was a large vacuum leak code which points directly to a bad gas cap. The next day after that I had the code read again and this time had all codes cleared.
No light or problem since that time.
Old Feb 16, 2011 | 01:48 PM
JagV8's Avatar
As I recall, USA law mandates that the MIL be automatically extinguished (once the fault is not there) within specified times/conditions. I expect Jaguar conform to that law since there are seriously large penalties for failing to do so - some of which they incurred in the past.
It would be quicker to clear the code, though
Old Feb 16, 2011 | 02:19 PM
Enthusiast's Avatar
Right, part of the OBDII code. He`s right (jagv8).
bdboyle
Sep 16, 2019 05:58 PM
RSpi
Mar 21, 2016 12:02 PM
emilime75
XJ XJ12 ( X305 )
Oct 19, 2015 09:55 PM
Lannyl81
Sep 20, 2015 08:56 PM
