Changing Automatic Transmission Loom Harness 2006 2.7D S-Type
Old Jan 14, 2017 | 08:00 PM
Jaguarsmg1's Avatar
Default Changing Automatic Transmission Loom Harness 2006 2.7D S-Type
Does anyone know how to, or knows of a video that explains, how to change the Automatic Transmission Loom / Harness on a 2006 2.7D S-Type without removing the transmission PLEASE?
The 2 big plugs are way up in the bulkhead area and almost no chance of reaching them from underneath, and can't see how to reach them from above. Can't see any access pannel at the top of the drivers footwell (there is a soundproof rubber blanket up over that area anyway) or anything like that, so a bit baffled.
Genuine suggestions that do not require engine or transmission removal please? I want to avoid that if at all possible...
Thanks.
Mark
Old Jan 15, 2017 | 10:02 AM
JagV8's Avatar
Never heard anyone needing to do it so may be no such help.
Old Jan 15, 2017 | 03:32 PM
Homersimpson's Avatar
I know the plugs you mean, I took this apart when I changed the engine in a 2006 S-Type 2.7D. As I was stripping it all down access was relatively simple.
Can you access them by removing the wipers, scuttle cover and the steel bar that runs across between the two struts?
Old Jan 16, 2017 | 04:34 AM
Jaguarsmg1's Avatar
Thanks I will have a look. Looking at removing the footwell padding and cutting a small hole where they are to unlicp them and replace them and then tack a plate in over the hole. Might be the only other way.
Thanks.
