Changing Oil and Where To Get Info on Maintenance
Old Mar 26, 2008 | 09:24 AM
snooktarpon's Avatar
Default Changing Oil and Where To Get Info on Maintenance
I'm in the process of doing some basic maintenance on my recently acquired 2000 S-Type.
In terms of changing the oil. the Jag maintenance sheet states to "renew the drain plug assembly". Is this just a crush washer? Is this required for every oil change or just based on visual inspection?
In addition, I want to perform other maintenance so I purchased the JTIS CD ROM on Ebay. The problem is that it doesn't seem the cover basic maintenance, mainly bigger service jobs like removing the engine. I couldn't find changing the oil, while I know is this is quite simple, I though it would be included in the JTIS CD. In addition, it's not very descriptive. For example, it tells you to remove an item and it will have a cartoon picture associated with it but that's it. It doesn't tell all the other issues that will come up when removing that item. I've used a Cylmer manual for my BMW motorcycle and that manual was awesome. So are there other sources of getting maintenace and service for 2000 S-Types besides the JTIS CD (and this forum)?
Sincerely,
Jim
Old Apr 6, 2008 | 10:33 AM
reddrawf's Avatar
Default RE: Changing Oil and Where To Get Info on Maintenance
I'm with you on the JTIS CD. I was disappointed when I got mine for the same reason s you point out.
I did a google on Jaguar S-Type repair books and could not find any. You might do a goggle on S-Type oil change. As I recall, I read somewhere that it was no different from any other car. There is a plastic shield under the engine you have to remove first and then its like any car.
The last oil change I got was from a Jaguar mechanic and using synthetic oil it cost me $125! DIY should save a lot!
Good luck and please post the details of the job when you do it.
Old Apr 6, 2008 | 11:15 AM
FactoryJaguarTech's Avatar
The 4.0 is easy. Remove the drain plug, new one will have washer on it. The filter is right at front of engine. Takes 7 quarts.
The 3.0 is trickier, although same procedure except the filter is at rearside (drivers) of motor. Above the power steering lines and right in front of the cat. Also takes 7 quarts.
The 2000-2002 S did not have the engine undertray. 2003 is when that malarky started.
You think it is tough to do an oil change using JTIS? Try working on these for a living and having to use that kind of guide to work on the car.....lol. We find alot of shortcuts. The pictures suck.
Old Apr 6, 2008 | 12:13 PM
reddrawf's Avatar
I'm actually considering going to a fast oil change place. I have been using them for years for my wife's Quest and when I had an Explorer (before I sold it and bought my Jag). They sell Royal Purple oil and the oild change would be about 90 bucks. Still expensive but a lot less than the Jag mechanic or the dealer.
Any thoughts?
Wolfy
May 28, 2024 08:06 AM
ZJag
26
Sep 5, 2016 03:33 PM
bdboyle
Sep 4, 2015 06:16 AM
Jag-o-nomic
Sep 4, 2015 03:07 AM
pnwrs2000
Sep 3, 2015 11:55 AM
