Cigarette outlet not working.
Old Jun 7, 2016 | 02:39 PM
FLStype's Avatar
Default Cigarette outlet not working.
2003 S-Type V6 The cigarette and power point outlet not working. I've changed the F32 fuse and it still doesn't work. I checked the outlet to see if anything dropped in there. No dice. Any ideas? Thanks
Old Jun 8, 2016 | 12:13 AM
Datsports's Avatar
does sound like there is another fuse eluding you , i would just check all the fuses with a test light remember there are three fuse boxes through out the car . worst case could be a broken wire in the loom but id doubt that though.
Old Jun 8, 2016 | 11:29 AM
2000JagLvr's Avatar
+1 Above.
I would check the fuse that you installed. It could have blown as you inserted it.
Is there power to the fuse at this point
Old Jun 8, 2016 | 11:46 AM
FLStype's Avatar
I will check for power.
Old Jun 21, 2016 | 08:40 AM
FLStype's Avatar
I went to the local junk yard and pulled a R1 relay. Now the system works again.
Old Jul 24, 2016 | 04:44 AM
VanZyl Zyla Muller's Avatar
Hi... Do you think it wil work on 1999 S-type 4.0l v8
Old Jul 24, 2016 | 01:00 PM
FLStype's Avatar
Its worth the try.
bebxtd597
22
Dec 29, 2018 01:26 AM
Sparky77
May 9, 2016 08:15 AM
EZrider800
47
May 16, 2011 01:14 PM
tncc_rn
Jun 17, 2009 06:28 AM
