Cruise Control Not working Overspeed Warning
Old Apr 24, 2019 | 01:09 PM
Jaguarsmg1's Avatar
Default Cruise Control Not working Overspeed Warning
I recently had a new PCM fitted and since then when I try to use cruise control I get a warning saying I am overspeeding and that limiter is not available.
It was a friend who installed it and he has never seen it before and does not know what do do, but I am now stuck with it.
My S-type does not have a switch for Speed control, so I can't just switch it off.
I have tried the usual fixes of kicking it down a gear etc, but no joy.
I have tried to find a fix to change it on the SDD software but nothing.
Ii am stumped. Anyone have any knowledgeable advice on how to get back to having cruise control please?
Thanks.
Mark
Old Apr 24, 2019 | 11:56 PM
scottjh9's Avatar
I believe the pcm is vin specific to each vehicle....i also think you have to deal with the vin via the vid block....there is a tsb in the stickies that addresses a pcm swap....that is the extent of my knowledge
Old Apr 25, 2019 | 04:04 AM
Jaguarsmg1's Avatar
Hi,
I have now reinstated the old PCM as the issue was a double MAF failuyre and not the PCM. The Speed limiter Over Limit issue is still the same, so I can't see how it is Vin specific as the SDD software used to change it reads the Vin and uses that.
Thanks.
Old Apr 25, 2019 | 10:50 AM
scottjh9's Avatar
Originally Posted by Jaguarsmg1
Hi,
Thanks.
I may be wrong, but it is vin specific in relation to the other modules especially the trans control module....i am correct that your overspeed is actual vehicle speed and not rpm...i wish i could point you to the tsb i am referring to....hopefully one of the members will remember what i am referring to and chime in
Old Apr 25, 2019 | 10:12 PM
scottjh9's Avatar
Here is the tsb i was talking about...if you have not seen it, maybe it will help...thanks to motorcarman for posting on another thread
File Type: pdf
Old Apr 26, 2019 | 05:37 AM
Jaguarsmg1's Avatar
Thanks for that. I will have a good read tonight and see if I can edit it myself and see if this resolves the issue.
Have a great week.
Mark
Old Apr 26, 2019 | 05:56 AM
Jaguarsmg1's Avatar
Can this be edited please?
If so, what with?
Thanks.
M12345678
Jul 14, 2016 12:49 PM
JustNiz
Apr 25, 2012 08:50 PM
denisecdb
Apr 10, 2012 11:08 PM
mcs
Jan 15, 2012 10:25 PM
