Curious headlight problem
Old May 6, 2015 | 04:10 AM
raistlin295's Avatar
Default Curious headlight problem
Hi all,
Both of my dipped headlights have stopped working. It isn't the bulbs and according to my handbook there are no specific fuse(s) for standard halogen dipped beams.
I'm guessing it must be something common and was wondering if there was any common connection, apart from the stalk switch.
Any ideas please?
Old May 10, 2015 | 09:24 PM
Warspite's Avatar
Check your "auto lamp" switch assembly. Pop it out and spray the contacts. My fog lights wouldn't work, and electric contact cleaner like DeOxIt D5 did the trick on that rotary switch.
Old May 11, 2015 | 12:58 AM
Thank you. Good idea.
Old May 11, 2015 | 02:07 PM
Now fixed .
Curiously enough, the problem was that apparently, H7 bulbs, particularly, el cheapo items, can fail in such a way that having removed the bulb, one can carry out a continuity test and the bulb will appear satisfactory but when pushed into the connector, the contacts, then under tension, move enough to cause an open circuit.
So, in the end, it was a simple case of replacement bulbs from a known manufacturer. In my case, Hella.
99xk8guy
May 28, 2024 09:36 PM
afterburner1
Dec 16, 2015 12:12 AM
mcdutch
Sep 4, 2015 03:38 AM
laserguy
Sep 3, 2015 02:02 PM
dcvickers
Sep 2, 2015 06:14 PM
