Dome lights
Old Nov 5, 2018 | 03:44 PM
Pwnuk's Avatar
Default Dome lights
Hey guys. Read a couple threads of problems with dome lights. At first my problem was with car door rubber button. Fixed that and problem came back. For the short term I just removed the bulbs on my interior lights. Will that solve problem of draining battery? Was going to disconnect battery to disengage lights but felt removing bulbs was better temporary solution.
Thanks for any insight.
Old Nov 5, 2018 | 10:48 PM
Datsports's Avatar
you are lacking some crucial car information , what year ? is it an S-type ?
2002.5 onwards s-types will go to sleep in about 15mins regardless of the door being open (or the door switch telling the cars modules the car has a door open)
when the car goes to sleep the lights should switch off with the modules .
if the car is not going to sleep there is another issue .
if the car is going to sleep and the interior lights stay on there is a module relay issue .
Old Nov 10, 2018 | 12:57 PM
Pwnuk's Avatar
Thanks! It’s a 2001 s type. Lights don’t go off after 15 minutes. Actually took all the interior bulbs out and still ran battery out.
where would the module relay be located?
Old Nov 10, 2018 | 01:00 PM
Pwnuk's Avatar
Got it. In the fuse box.
anyway to test it? Which one would I be looking for?
thanks.
Dani Santos
Aug 23, 2017 06:05 PM
BradOKeefe
Jul 30, 2015 01:01 AM
edra566
35
May 21, 2015 09:02 AM
jagxtypeboy
Jan 19, 2008 06:52 PM
