Door check strap
Old Mar 11, 2010 | 05:46 PM
edhowey's Avatar
Default Door check strap
I have just discovered that the drivers side door check strap bracket is broken on my 2002 S-Type Sport. Has anyone replaced one of these? I can see the two torx screws that will detach the bracket from the "A post" but I am not sure what will be required to detach the strap from the door. I would appreciate any comments.
Ed
Old Mar 11, 2010 | 06:20 PM
joycesjag's Avatar
Reaching into our '05 door, where the bracket goes into the door, I feel two nuts (ahemmm really) in there that holds the anchor point for that end.
Old Mar 11, 2010 | 06:23 PM
joycesjag's Avatar
A deep well 10mm will work the best. A short well 10mm is tight.
Old Nov 22, 2013 | 07:58 AM
Jimbo's Avatar
Default 2001 3.0 S-type front door stay
Are the front door stays handed and are the rear a different shape?
Also noted someone has a set for a 2.7 S-type are they compatible with my 3.0 model?
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
Dz1rfj
Jul 17, 2018 10:29 AM
GordoCatCar
Jan 2, 2017 01:10 PM
al_roethlisberger
Sep 11, 2015 10:04 PM
