DSC Traction control problem
Old Apr 11, 2009 | 06:55 AM
JOsworth's Avatar
It could be a brewing problem, but I'm not sure how to test without getting a Jag dealer involved. I say this because soon after I got my 05 the DSC system activated while turning left in damp conditions. Right after that the display would say "DSC Fault" on the display. It would display the error sometimes and not other times. I took it to the dealer. They didn't even road test it......The service manager said "Ahh, we know what that is" and they replaced the ABS controller and master cylinder. Problem solved. They said that the two systems are so interconnected that you could have a brake issue that ends up tripping the DSC system before it causes a drivability issue. I say that because the whole time the brakes worked fine, including ABS. Since they fixed it months ago the system has been great. Even allows for some wheel spin (chirp) under hard downshifts without jumping in. Hope this helps.
Old Apr 15, 2009 | 10:27 AM
JOsworth's Avatar
Great to hear it was a simple fix. I highly advise you get matching tires as soon as you can.
Old Apr 17, 2009 | 06:44 AM
JOsworth's Avatar
Good choice. Little jealous.... You've got 18's, I'm saddled with the stock 17's...
cissdm
May 3, 2016 06:02 AM
jdzubas
Oct 4, 2015 09:14 AM
XJsc-guy
Sep 25, 2015 11:09 AM
pocketrocket
Sep 3, 2015 07:44 PM
