DTC B1265 Cold Air Bypass Actuator Motor Drive Circuit Fault
Is 1A big enough? (*)
My new DCCV (not yet fitted) reads just over 14 ohms when cold. That's over 1A when the alternator is on boost (over 15V for a while).
(*) engineer-speak for "probably not"
I don't know how many people realise the alternator is programmed to put out different voltages (it's in JTIS if you're inclined to read)...
On your car, there a connector just below and to the RH side of the radiator, accessible from under the car. It's clipped next to the big cooling fan power connector. You can separate that connector and using the DCCV feed wire as a common, measure the resistance of both valves. That's for all S-Types 2003 and later.
For 1st generation S-Types, the connector to use is clipped to the fan shroud just below the MAF Sensor, also clipped next to the fan power leads.
That will save all that digging to get to the DCCV itself.
Cheers,
Cheers,
Well, the repair is complete and all is working as it should. The DCCV valve replacement was easy (except getting the wiring harness off the DCCV), the coolant bleed process was not difficult and the CCM now has a jumper and a glass 2A fuse replacing the burned trace from the pin to the Siemens BSP 78 chip marked as IC7. If the DCCV goes again and the resistance in the circuit drops from normal 14-18 ohms to 6-7.5 ohms, the fuse should blow and save the CCM from damage - maybe not as elegant as the circuit protection that some of the rebuild guys put in, but I can replace the fuse in the CCM easily if this happens again and I've saved another $150-$300 on a CCM rebuild. That is, if it works!
To be expected, but still shame on my Jaguar dealer for quoting $2700 for wanting to source a new CCM ($1500), Jag DCCV ($400) and then about $700 labour... This entire process took less than 2 hours and cost $250 at most - and if I'd have shopped around for a better deal on the DCCV it might have cost under $100.
Thanks to everyone who helped me with this, especially xjrguy and jagv8! I've overcome my fear of opening the bonnet and saved myself a small fortune in the process.
So is the current. Either the diode is always conducting or the circuit is disabled so what is it doing that's useful?
Vern
Ignore the B1265 fault code. The stated bypass actuator was removed starting with VIN# N10330. Consequently, that code will always be there as there was no software change in the Climate Control Module.
That means you'll have to go back to the other possibilities for the heat all the time; most likely the DCCV, the Control Panel or a wiring fault.
Good luck!
Good luck!
BrentGardner
29
Dec 16, 2024 12:13 AM
FS[Central US]: 1999 XJ8 Parts or project car for sale Lawrence, KS
casepie
Aug 30, 2015 09:49 PM
