ECM fault code, replacement, advice?
Old Feb 20, 2012 | 03:38 PM
07BlackS-TypeV8's Avatar
Exclamation ECM fault code, replacement, advice?
First had Amber warning light come on...had coded and showed an ECM fault...not long after...the Red warning light came on upon starting and show ABS failure in the message.
Before taking to shop, thought I would inquire here. ECM need replacing? Estimated cost for this fix? Possibly a quicker less expensive fix? Anyone else with similar experience?
Thanks.
Old Feb 20, 2012 | 04:40 PM
JagV8's Avatar
What was the actual code?
Could you have a failing battery?
99.9% the ECM is fine. Make it the very last thing you think about.
fast40driver
Apr 19, 2024 07:24 AM
philwarner
Dec 6, 2021 07:13 AM
X_Type_South_Africa
Dec 9, 2015 05:37 PM
Drew2006
Nov 24, 2015 11:14 AM
rudelover2
Sep 11, 2015 08:53 PM
