ECU change and reprogram after AJ engine swap
Old Dec 7, 2021 | 03:37 PM
elDariusVargas's Avatar
Default ECU change and reprogram after AJ engine swap
Hey!
Name's Darius Vargas, and i have posed a thread about a 2.5 to 3.0 engine swap. Reason: cheap good AJ30 engine, and overheated the Aj25.
Everything worked out well besides 2 minor issues, that might be another thread's subject.
both cars (mine and the donator) are 2003 with ZF6hp26 models (with some slight extra options differences) (ECU codes are very simmilar. i can post a side by side picture if their codes isnt private info?)
Now i've ran the car home with the 2.5 ecu and 3.0 engine, but i want to install the 3.0 ecu and pair it to the car so i can keep my key and electronics & so i dont have to change the cluster, ignition, door module, key, door&trunk latch etc.
All this information for a simple question: Can anyone please tell me the procedure to pair the new ECU to the rest of the car and reset my ZF parameters?
Can i use a JLR mongoose?
Many many thanks. Swap pictures incoming in the reply tomorrow
Old Dec 7, 2021 | 04:08 PM
xalty's Avatar
program as new module in IDS/SDD follow the steps as prompted. it will copy the original VID into the donor
cheap mongoose will be risky
Old Dec 7, 2021 | 04:55 PM
oh ok, so it would be a rather fast forward procedure if i have de ids ssd.
thank you
let me also post some swap pics for fun
Painted and refurbished aj30 i added the lpg kit harnesses nicely on top
Cats cleaning - successful. Should've seen the datk green water that went straight to the waste truck
In with the 30
Gold painted is the 30, black one is the 25
Out with the 25
Old Jan 2, 2022 | 06:22 PM
Sorry for the second post, i wanted to conclude the operation
UPDATE
complete success:
i am running the 3.0 ECU from the donator car, with my original clusters, alarm module and keys.
i had someone reprogram its immobilizer for me.
its better than trying to remap the 2.5 one
especially if you have an automatic transmission.
elDariusVargas
Jan 3, 2022 05:13 AM
Bruiser
Jan 9, 2019 09:55 PM
Robert Gladding
Aug 1, 2017 08:45 PM
nahum
Nov 21, 2015 11:02 AM
julien4020
May 2, 2015 12:52 PM
