electrical gremlins
Old Oct 18, 2016 | 02:02 PM
chris92026's Avatar
Default electrical gremlins
hello
new here
just got a 2001 s type auto 3.0 (us model)
love the car so far
i do have some electrical problems
passager window not working
both mirrors are bot working
doors switch do not illuminate(not sure they do but most of the car do )
so has the lights on bottom of doors (dome light works)
truck light do not work
left licence plate light not working went the trunk is open
fuse are good
can he be a bad ground ???
thank you
Old Oct 18, 2016 | 03:16 PM
NBCat's Avatar
Check fuses and connections.
Did you find water in the boot (trunk)?
What is the age and condition of the battery? A failing or weak battery can cause random DTCs to be set along with other electrical 'faults'. With the ignition in the off position, the battery should have no less than 12.2 volts across the terminals. It is best to replace the battery if there are no more than 12.5 volts across the terminals with the engine not running.
Old Oct 18, 2016 | 06:40 PM
Gus's Avatar
Gus
Check the bulbs and make sure you have voltage to it.
As for the window check the fuses but you could have a bad motor.
I guess you are saying that the mirrors are not working. I would need to check on what controls the mirrors but the fuse is the first place to look.
Gus
www.jagrepair.com
Old Nov 1, 2016 | 03:01 PM
chris92026's Avatar
Anyone has the fuse diagram for the 2001i only find for 2002
Old Nov 1, 2016 | 04:50 PM
Gus's Avatar
Gus
Is this what you are looking for?
Link http://jagrepair.com/images/AutoRepa...x2022001en.pdf
