Engine Coolant Low indicator - please help
Old Sep 30, 2008 | 09:41 AM
Default RE: Engine Coolant Low indicator - please help
My money is on a cracked reservoir, it's a common fault, fill it right up and watch for leaks around the tank
Old Sep 30, 2008 | 09:49 AM
Brutal's Avatar
3THINGS ON THE CAR FOR COOLANT LEAKS
#1 LINE ONTOP OF RESERVOIR CRACKED, MOVE IT AND YOULL SEE MORE THAN LIKELY
#2 THERMOSTAT HOUSINGS CRACK
#3 ON THE UPPER COOLANT HOSE MATRIX, THE PLASTIC PIPE HAS A FITTING ON TOP THAT CRACKS TOO
AS WITH ANY COOLANT LEAKS WHEN YOURE OUT ON THE ROAD, KEEP THE RESERVOIR FULL AND DO NOT TIGHTEN THE CAP FULLY OR THE SYSTEM JUST BUILDS PRESSURE AND FORCES COOLANT OUT EVEN FASTER OR WILL CAUSE THE LEAK TO TOTALLY FAIL.
DO NOT LET COOLANT LEAKS GO AS EVEN THOUGH THE ENGINE DOESNT SHOW OVER HEATING YOU CAN DEVELOP AIR POCKETS IN THE SYSTEM AND LOCALIZED OVERHEATING ESPECIALLY IN THE HEADS THAT CAN LEAD TO DROPPED VALV SEATS AND LOSS OF COMPRESSION(READ NO COMPRESSION NOT LOSS OF)
Old Sep 26, 2009 | 04:41 PM
yjmcb's Avatar
where can you buy the resevoir and the other plastic fitting,mine just broke.yjmcb
Old Sep 27, 2009 | 12:45 AM
Have you tried the dealer, or maybe fleabay if you have the time.
Or here http://www.jagbits.com/mm5/merchant....Type_Cooling_4
Forcedair1
Sep 8, 2025 01:57 PM
jehart49
Sep 12, 2015 05:36 PM
KarimPA
Sep 3, 2015 07:32 PM
Bcrary3
Sep 3, 2015 03:48 PM
OkieTim
Sep 2, 2015 12:48 PM
