Engine knocking during startup, please HELP!!!
Old May 4, 2008 | 03:11 PM
hlgeorge's Avatar
Default RE: Engine knocking during startup, please HELP!!!
You may have a problem with the timing chain tensioners, a very common problem with the 4.0 V8 engines. They were made of plastic and will break at some point. The new replacements are made of metal as they are on the 4.2 V8 engines. Be careful, if one breaks, you could destroy the engine.
Old May 4, 2008 | 06:07 PM
cosworth's Avatar
your local ford dealer has the tools to do this. but - it's an ugly job.
Have you heard of an engine needing a cam belt once or twice in its life? Well this si the same. You need to service the cam tensioners and chains once in it;s life. i just did mine, replaced all the tensioners and guide plus ONE chain. Pricey but I have faith in this motor knowing it is bulletproof for many years.
Get a dealer to look at it then decide.
Old May 5, 2008 | 06:25 PM
jag_genius's Avatar
but you will be spending more money.. it's either gonna be alot or a whole lot.
SD96XJ6L
Jan 12, 2022 04:30 AM
cissdm
May 3, 2016 06:02 AM
OkieTim
Sep 8, 2015 04:48 PM
robiwhan
Sep 4, 2015 10:43 AM
OkieTim
Sep 2, 2015 12:48 PM
