Engine Light - P1647 code
Old Jun 1, 2011 | 10:41 AM
03jagstype's Avatar
Default Engine Light - P1647 code
Hello
Help needed please....
Had the light pop up and took the car to Advanced Auto for a reading.
P1647 02 sensor code
Which would make sense as my MPG has been crappy IMO. But I'm going to go ahead and test everything to verify if I can. I found this site for reference:
Automotive Circuit Testing - Help With Check Engine Light Diagnosis
I know there are plenty of threads on this topic that I've looked up, but I had some other questions...
1. Can someone point me to a USB ELM device on eBay that will work with the Stype? Ive emailed a couple of eBay vendors and both have come back with non compatibility.
2. The guy at the Advanced suggested a Bosch sensor that was less expensive than an OEM one should I need to change it out - he stated it works exactly like the OEM.... Thoughts?
Thanks!
2003
S-Type 3.0
Old Jun 1, 2011 | 10:43 AM
phd12volt's Avatar
driver side upper O2 sensor
same one i had. Brutal sent me the info for it. Amazon is about 87 dollars + shipping
My factory o2 part number is C2C 29 250
DENSO replacement part is 234-9030 and was under a hundred shipped 2 day
weird the price just went up after i ordered it....... http://www.amazon.com/Denso-234-9030...ar=1&carId=001
Old Jun 1, 2011 | 11:44 AM
JagV8's Avatar
Seems to me that ALL the elm327 tools will be fine but the sellers likely never heard of the S-Type / simply don't know.
That circuit testing site seems on a quick look to mention using a test light. In general, with modern cars - don't.
(If you understand why I say that, then do use one when you're sure it'll be OK.)
Old Jun 2, 2011 | 01:20 PM
03jagstype's Avatar
weird the price just went up after i ordered it....... Amazon.com: Denso 234-9030 Oxygen Sensor (Air and Fuel Ratio Sensor): Automotive
Thanks! I ordered the sensor from Amazon.
I had the lady at Advanced auto first insist I needed 234-4798 not this one, so when I googled I see she was insisting it was the rear one, so I just went the Amazon route, cheaper and just a day or two more wait. Plus she quoted me the wrong price initially at $92.98 locally, but when I showed up to buy the price was $187.09 !!!
Napa guy said they didn't carry this but that the Bosch 15626 was exactly the same at $109, but 5 days wait. I chose to trust the experts here rather than risk getting a part that isn't compatible or user friendly.
THANKS again!
Isoruku
Jun 19, 2020 12:54 PM
X_Type_South_Africa
Dec 9, 2015 05:37 PM
big d
Sep 3, 2015 07:37 PM
Jandreu
Aug 29, 2015 07:31 PM
daro31
Aug 27, 2015 09:26 AM
