engine stops above 2100 rpms - code P1586
Old Aug 23, 2017 | 04:41 AM
Ducmon's Avatar
You can get a pdf here for twenty bucks. it will save you a lot more than it costs
Jaguar S-Type 1999-2002 Factory Service Repair Manual pdf
Old May 29, 2018 | 09:21 AM
LAjag's Avatar
Default HELP! Jaguar shop mechanic completely confused --
Any thoughts????
this message is from jag owner who began this thread.
My Jaguar is in Los Angeles official Jaguar Dealer service center
Service tech Attempting to clear a P1586 code. .. told this to service manager......
Service tech told service manager ..
"no progress on download.
No coms (communication) with ECU"
"Think it (2001 S-type v6) may have a frozen task bar"
Any ideas or thoughts?
they are stymied.
Old May 29, 2018 | 03:36 PM
Ducmon's Avatar
Originally Posted by LAjag
Any thoughts????
they are stymied.
I had this once on my car turned out that the battery did not have the correct voltage and was unable to power everything correctly. Check the voltage it should be 12.6 volts
Old May 29, 2018 | 10:58 PM
scottjh9's Avatar
hello LAjag
I have a digital workshop manual on my computer for the s type from 2002.5 to 2008...I downloaded it from this forum...I run windows 7...I live about 175 miles north of you in the central valley...I will gladly load it onto a thumb drive and mail it to you if you like if you still need it...i know you are working on a 2001 but this manual might help if you cannot load it yourself from the forum link....let me know...I could mail as soon as tomorrow
Old May 30, 2018 | 11:13 AM
JagV8's Avatar
Same one as already on here and JagRepair.com - Jaguar Repair Information Resource probably.
Old May 30, 2018 | 12:09 PM
NBCat's Avatar
Here is a link to the Workshop Manual for the pre-facelift cars:
https://www.dropbox.com/s/jp6343385h...e_FSM.pdf?dl=0
Old May 30, 2018 | 02:07 PM
scottjh9's Avatar
yes I am sure it is because I downloaded it from the forum....so much good info and nice people here...I always look forward to learning from all of you
Old May 30, 2018 | 06:56 PM
  #28
LAjag's Avatar
Thanks to all of you....
just now getting back to this forum page...
Thanks for the S-type Service Manual links.
frustrating issue...
frustrating as well.. because also, seems we have to "educate" the Official Jaguar service techs.
Your answers were same as mine.. so I texted service manager..
"sounds like tech let battery get too low during the download. Because download will effect several modules, if current drops before finishing, some modules will be reprogrammed and others not...causing a variety of unknowns. Charger needs to be set at 13 -13.6 volts."
Old May 30, 2018 | 07:02 PM
LAjag's Avatar
Guess what ??
after a week at SM Jaguar Dealer.. a text arrived yesterday ..
"finished reprogramming OK to pick up car"
When I called back... seems car is same.. in Limp mode
They didn't deal with the P1586 and no communication between ECM/PCM and throttle body.
Old May 30, 2018 | 07:21 PM
  #30
LAjag's Avatar
Thanks NBcat .. Super!!
actual workbook ... 5056 pages
Old May 31, 2018 | 11:40 AM
  #31
Jon89's Avatar
Your dealership sounds incompetent on these older Jaguars. Not at all unusual - so is my local dealership....
Find a good local indie shop who knows the older cars. You will be much better off (and so will your bank account)….
Old May 31, 2018 | 02:02 PM
  #32
MyBlackCat's Avatar
I agree with Jon.
Take it to NB Cat. He can't be far from LA if that's where you are.
Old Jun 1, 2018 | 09:08 PM
  #33
LAjag's Avatar
Default a real headache
What would cause PCM to not recognize throttle body?
I swapped throttle body for another, and still have same P1586 DTC fault code.
Did continuity check on all wires between false bulkhead connector and TB connector. all seems fine.
week #2 at Jaguar Dealer service center in Los Angeles..
no progress...
Jaguar forum members are by far better suited than Official Jaguar Service center for discovery of answer to this puzzle.
Thanks again for your ideas.
Old Jun 24, 2018 | 12:15 PM
  #34
kr98664's Avatar
Because of code .. I replaced Throttle Body assembly with another from a low-mileage 2004 S-type...and
I get same problem.
Is 2004 a typo? Per your signature, you've got a 2001. Even if a 2004 throttle body will bolt up to a 2001 engine, I believe there were some significant electronic changes.
If the part is correct for your car, I wonder if it is defective. For all we know, the donor car may have been getting the same P1586 code before ending up in the wrecking yard.
As mentioned in a previous post, my '02 V6 had been occasionally throwing a similar P1584 code. I forget the exact details, but I'd suspect the fault is close to your code. A guaranteed used throttle body ($75) from eBay put the fault to rest, never to return. If you can find a similar deal, that might be worth a shot in case the donor part was bad.
Old Jun 24, 2018 | 12:23 PM
  #35
kr98664's Avatar
Just possibly it's a failing battery - they cause weird codes and are cheaper than a mechanic.
How about this one? Did you ever gamble on a new battery, as JagV8 has suggested? These cars are very sensitive to battery condition, even if the starter cranks over at normal speed.
Also note the clever way I left blame pre-assigned in case it doesn't help...
Old Jun 24, 2018 | 12:37 PM
  #36
kr98664's Avatar
Believe my problem is in white "W" (Actual Throttle Angle) input to PCM.
White wire gave an odd positive reading .. neither 1 nor 0
All wires tested good for continuity, except white wire.
"W" white wire seems to run from throttle body plug directly to
(located on right firewall)
Playing Sherlock Holmes here. Did you ever resolve this? You said you found a wire with no continuity. That's huge!
Per section 3.1 of the wiring diagrams, that wire is a straight shot from the TACM to the PCM. Assuming it's buried inside a big harness, and the fault is confirmed, you could splice in a new wire at each end and run it on the outside. That would be way easier than tearing the entire harness apart in search of one bad spot.
Old Jun 24, 2018 | 12:43 PM
  #37
kr98664's Avatar
Note: relay #4 in 2001 S-type is throttle control circuit relay
Last but not least, did you try swapping this relay? This had been previously xuggested, but no mention if you actually tried it. Find a non-essential circuit with the same relay. Make sure that circuit works properly to confirm the donor relay is good.
Old Jun 25, 2018 | 04:51 PM
  #38
LAjag's Avatar
Response question by kr98664
Among first things done...
swap relays
check fuses
disconnect battery... perform hard reset
continuity check wiring --between throttle body to PCM plug at false bulkhead (rt)
swap throttle body for used TB from similar car witb same eng size
Still in "limp mode"
As last resort .. sent car to dealer to reprogram PCM...
Last edited by LAjag; Jun 25, 2018 at 05:00 PM. Reason: need intended recipient information added
Old Jun 25, 2018 | 04:56 PM
  #39
LAjag's Avatar
Default response to kr98664
No... you misunderstood.
found odd reading on continuity ck white white wire. ... (note: probably issue with my test)
TO be certain of continuity... as you can read previously...
I created a new connection to bypass that wire with a new wire and new wire tested fine
Without any apparent change in engine, nor throttle Body
Last edited by LAjag; Jun 25, 2018 at 04:58 PM. Reason: need intended recipient information added
Old Jun 26, 2018 | 08:56 AM
  #40
kr98664's Avatar
Can you please confirm the model year of the donor car? I had asked previously, but didn't see an answer. In an earlier post, you had said the donor was a 2004, and your car is a 2001.
A quick look here shows different part numbers for the 3.0 depending on the model year (actually by VIN). Scroll down near the bottom of the page:
Throttle body part numbers
Up to 2002 takes p/n XR858418.
2003-2005 takes p/n XR845053.
