Fitting 20" rims comfortably?
Old Jun 29, 2007 | 02:38 AM
momo's Avatar
Default RE: Fitting 20" rims comfortably?
Dang you are doing big thangs Smooth. I don’t know how you can tell what the offset is, follow this link to http://www.tirerack.com/, it will tell what fits the S. You can take it to a shop they should be able to tell you what the offset is, I hope this helps.
Old Jun 30, 2007 | 06:45 AM
04Xtype's Avatar
the offset has to do with the wheel, you cud find out what it is from the guy ure buyin the wheels from, or take the wheels to a shop. Its a good thing that you get to try out the wheels before you buy. mak sure you test if they rub when there are people sitting in the bak and u aregoing over a bump. Also on the S's ive seen some where the front fender has been pulled out a little cos of the tire hittin it. Thetire is pretty low profile, so im guessin you should be ok. Oh and black rims on a black jag will look sik
DrTripp
Mar 22, 2020 09:33 AM
slojotaa
Oct 16, 2019 10:22 AM
JagBrian
Aug 18, 2019 05:07 PM
lickahotskillet
Oct 18, 2015 09:51 AM
lickahotskillet
Sep 11, 2015 07:54 PM
