Flickering headlights
Old Apr 13, 2012 | 07:13 AM
Rebekah350's Avatar
Default Flickering headlights
I found a similar post, but since it was for a different model car, I was asked to repost in my model's forum. So here it is. While driving the interstate the other evening, I noticed a flickering / dimming of both my headlights. I had this same problem about a year ago and found the problem to be a loose battery terminal. I checked the battery again, and all is well there. The other post mentioned it could be a relay switch. It doesn't flicker when I hit bumps or anything like that, it's just sporadic. Any tips or suggestions?
Old Apr 13, 2012 | 10:53 AM
bfsgross's Avatar
Turn signal/headlight light stalk (switch that turns the signals and lights on/off and/or loose harness plug into the steering column.
Old Apr 1, 2015 | 10:20 PM
1320racer's Avatar
Default Lights Flickering
Over the last several months, my STR's lights began to flicker every so often (...head lights, dash lights and navigation screen).
Recently, the head lights began to stay on but would turn off by simply touching/wiggling the turning signal stalk. Then, last night, the headlights would not turn off until the battery was disconnected. This morning, after reconnecting the battery, the head lights and dash lights would not turn on at all.
I removed the steering wheel and checked all wires and connections to the turning signal stalk. All were good so I'm replacing the turning signal stalk and will let you know how things turn out.
If you have similar issues this post may be helpful…https://www.jaguarforums.com/forum/s...val-faq-61287/
Old Apr 2, 2015 | 03:57 PM
tbird6's Avatar
Can you post the part number and cost when you change it out?
Old Apr 3, 2015 | 11:41 AM
1320racer's Avatar
I'm purchasing the part from Rock Auto and they list the Alternate/OEM Part Number as SW9351 (cost $162.99). I will likely not be able to install the part for 10 days as Im away on travel.
Old Apr 4, 2015 | 08:27 PM
1320racer's Avatar
Default Fixed
The new turning signal stalk arrived early and all exterior and interior lights work properly now with no flickering.
hoodun
Nov 20, 2022 02:35 PM
kingdom worker
Nov 14, 2020 03:47 PM
goges
Oct 5, 2015 04:53 PM
Fletch44
Sep 28, 2015 02:21 PM
kevinl
Sep 24, 2015 08:25 PM
