Front Brakes S type
Old Jun 1, 2010 | 08:30 PM
FloridaJag's Avatar
Default Front Brakes S type
As someone who likes to do things on the cheap, I decided to do my front brakes after work today on my 2003 3.0 Stype. Piece of Cake. Purchased made in the USA Akebono ceramic pads. Used 12 mm socket to remove the calipers. After removing calipers, used a standard made in USA pad spreader and original pad to push the pistons in. Installed pads on bracket and then installed caliper. Installed calipers using 12 mm bolts. Viola, the car now has excellent ceramic pads which hopefully will reduce brake dust.
It's a real easy job for the fronts. Are the rears that easy?
Old Jun 2, 2010 | 06:22 AM
joycesjag's Avatar
Good job! There is a special tool that will be needed actually made. Do a search of JOsworths thread about a year ago on his rear brake job. He describes where to purchase and how to modify the special tool.
Old Jun 2, 2010 | 06:37 AM
joycesjag's Avatar
Heres the link, Jeff tells you how to "modify" in the #1 post right after discussing the front replacement.
https://www.jaguarforums.com/forum/s...ht=wheel+brake
Old Jun 2, 2010 | 06:49 AM
carelm's Avatar
FloridaJag,
Well done! What brand of pad spreader did you use? I may be doing something similar later this summer. I originally thought about a C-clamp but if a special tool is reasonably priced I may go that route. The way Jaguar designed the fronts is pretty slick in my opinion. One bolt to raise the calipers, plop the new pads in after spreading the calipers and you're basically done.
Mike
stanjag
Dec 29, 2024 08:26 PM
BrentGardner
29
Dec 16, 2024 12:13 AM
Doberman_Fan
22
Dec 24, 2019 06:21 AM
Fraser Mitchell
Oct 1, 2015 04:06 AM
nelsonht
Aug 30, 2015 06:01 AM
