Front Upper Control Arm Replacement Advice needed
Old Oct 25, 2014 | 11:01 AM
cppeabody's Avatar
Default Front Upper Control Arm Replacement Advice needed
Dear Members,
I need to replace the front upper control arms on my 2000 3.0 S-type, and I will be replacing the vertical stabilizer bars as well.
I know that I need to remove the shock struts to replace the upper control arms. My question is that if I disconnect the vertical stabilizer bars, will this allow the lower control arms to drop far enough so that the shocks can be removed and replaced without a spring compressor being needed?
Old Oct 25, 2014 | 05:33 PM
cat_as_trophy's Avatar
Hello cppeabody, and greetings from Australia.
Answers to your questions (and much more) all covered in detail in JTIS - words, pics, and a methodical sequence you can step through before picking up your first spanner. There are safety considerations to observe, so rather a than quick throw-away answer, you will be better served by first downloading here (Stickys at top of section) then come back for any clarification you need.
OK? Please don't see this as a brush off. It was the best advice I received too many years ago. If it was true then, back in the days of factory printed workshop manuals that cost an arm and a leg, how much more appropriate when all the info you should start with is just a few clicks away?
Best wishes and keep us posted,
Ken
Old Oct 27, 2014 | 09:48 AM
TonyX's Avatar
Originally Posted by cppeabody
Dear Members,
The answer is no. There isn't enough clearance without removing the shock/spring unit.
And JTIS download is single best thing you can do.
xjrjag
Nov 27, 2025 09:16 AM
Doberman_Fan
22
Dec 24, 2019 06:21 AM
Paradigm
Jun 15, 2019 05:59 AM
aquifer
Aug 29, 2015 04:54 PM
divingmom
Aug 25, 2015 07:54 PM
