Fuel damper problem
Old Jan 31, 2008 | 06:01 PM
FactoryJaguarTech's Avatar
Default RE: Fuel damper problem
The fuel damper is part of the fuel rail. The fuel rail is a readily available part.
If you cannot live without your car, I suggest you change it. It will have all new injectors etc on there.
You could call Jag also and tell them you want it at cost due to the fact that you cannot get the part you need and it is not feasible to leave your car parked for a year.
Old Feb 1, 2008 | 01:05 PM
Dennis's Avatar
ud
Seems to be and echo in here...
Old Feb 1, 2008 | 06:13 PM
Crawford, please lighten up. He was kidding and I AM trying to help.
You said you ordered the fuel rail. I dont quite understand what you said.
Did you order it, receive it and found that the damper wasnt on it? Or did you order it and you haven't received it yet.
I am not a parts guy so I couldn't tell what should or shouldnt be on there. I have
to work tomorrow so I will look up what you need. I haveyour vin.
I do advise against taking apart the damper. Personally I have not replaced just the damper. Only the fuel rail and
every one ive replaced, 2000-2002 have all had the damper on there.
I will repost tomorrow.
Old Feb 1, 2008 | 07:01 PM
lrizzell's Avatar
A few ideas that may or may not work. If the part has fitting on both ends, maybe you can bypass it for now. Not sure if this is unhealthy for the vehicle though.
Also, if the vehicle is under warranty, you may have some legal rights under the "Lemon Law" if you have such a law in your state.
Mostly though, I would have some real concerns if there is a fuel leak which could be hazardous.
By the way, you are in great hands with Factory Jaguar Tech!
Old Feb 1, 2008 | 07:23 PM
Old Feb 2, 2008 | 03:10 PM
Ok I checked on your part number from above. Updated as of yesterday, a small quantity will be shipped out this week.
Contact your dealer and tell them to put it on rapid recovery. That way they will get one.
Hope this info helps.
Old Feb 4, 2008 | 09:24 AM
Please read my above post. The damper will be available this week. But you will have to go to the dealer to order it.
Tell them to look at epc for availability and there is a note saying some are being shipped this week so get on it asap. Limited quantity.
toronadomike
Jan 22, 2026 10:13 PM
RoyLittle0
May 25, 2023 02:38 AM
jdzubas
Oct 4, 2015 09:14 AM
alpecsa
Sep 7, 2015 11:55 AM
Tar
Sep 6, 2015 11:24 AM
