Fuse blown/ battery sign is on PLEASE HELP!
Old Sep 16, 2009 | 05:28 PM
Thermo's Avatar
Veteran: Navy
Shawty, check fuse #11 in the front distribution box. If that is blown, that can be causing your battery light to come on. If it isn't that, then check fuse #5 in the rear distribution box. Either one of those can cause your alternator to not play nice. Since you are not complaining about the car not running or shifting funny, I can assume that your powertrain control module is working fine (controls the output voltage of your alternator).
As for your HIDs causing issues, where all did you connect up wires? This will help me figure out where your problem may lie and give me a few points to tell you to check.
Rivguy
Nov 13, 2022 02:55 AM
eurotire
Sep 18, 2015 07:27 AM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
jehart49
Sep 12, 2015 05:36 PM
oyster
Sep 12, 2015 01:01 PM
