Gas gauge
Old Jan 28, 2008 | 10:38 AM
super_jag's Avatar
Default Gas gauge
WhenI fill up my tank it only goes a hair past the 3/4 mark but not all the way to full. Any suggestions? oh and its a 2004 S Type and its a 6.
Old Jan 28, 2008 | 10:56 AM
FactoryJaguarTech's Avatar
Default RE: Gas gauge
Needs fuel level senders.
There is a TSB for replacing the arms and harnesses. Or you can just replace the pump and jet pump assy. A little more pricey if you are out of warranty though.
WHen you have it filled up, with ignition off, hold in the trip button, turn key on to position 2 and count 5 and let go of trip. Should say test mode on instrument pack. Each press of the trip button will show a different reading for different things. Keep pressing until you see Raw Fuel 1. Make a note of the reading. Press trip again and will show Raw Fuel 2. Make a note of that one too. Post the results and I will let you know which one if faulty if possible.
Old Jan 28, 2008 | 12:13 PM
super_jag's Avatar
ok i'll check it out
Old Jan 28, 2008 | 01:36 PM
super_jag's Avatar
Raw fuel 1 - 149
Raw Fuel 2 - 133
Old Jan 28, 2008 | 01:46 PM
Those readings are about right.
How much gas did you put in? I have had a few where I needed to put a tank in
due to it shutting off the fuel before being full.
Run it toward empty and fill again. You need to see if it takes full tank to determine
if it is the senders or the tank.
Old Jan 28, 2008 | 01:54 PM
super_jag's Avatar
ok I let it empty, I usually try not let the tank empty but we will see what happens. Thanks I will post the results
aode06
Jul 28, 2023 02:26 PM
hkmcmast
Nov 29, 2015 06:56 AM
workworkwork
Oct 23, 2015 10:26 AM
Spazzzzzzzzzy
XJ40 ( XJ81 )
Oct 5, 2015 04:05 PM
