gear box fault
Old Dec 24, 2013 | 04:12 PM
christophersexton236's Avatar
Default gear box fault
Evening all, i recently had a problem with my jaguar, the water tank cracked, so i replaced this, after replacing this(as a little bit of water came out of the bottom pipe) the gear box fault light came on, i had this checked out by a garage and recommended replacing gearbox, to which i had done, with one that came out of a 78K jag s type, which has not got ride of the fault, ive had them whiped, but as soon as i start up the car it comes strieght back, as i said ive already replaced the gear box and i know this was working fine before i had it installed, it just strikes me as weird as it only came up AFTER i changed the coolant tank. is there anything below this that anyone knows of that could affect the electrics to the gearbox or something as i am baffled and cant afford the garage to keep the car for a few days to search for the problem?
any help would be appreicated, the car is a jaguar s type 1999 3.0 auto
Old Dec 24, 2013 | 04:23 PM
Gus's Avatar
Gus
What is the code they pulled?
Old Dec 24, 2013 | 05:40 PM
solonoid b c short circuit for both and faults on both before and after change, same with torch converter, they wasnt there before i changed that bleeding water tank tho :S, the garage recons its an earth fault or electrical fault? any ideas?
Old Dec 26, 2013 | 03:24 AM
police666's Avatar
1st change garage
2nd find a good gearbox or jag indy, you have a ford gearbox in your jag so it shouldn't be too hard to find a garage who actually know what they are doing
tomsjag
Jun 10, 2023 10:02 AM
Jandreu
Jun 30, 2022 03:10 PM
cissdm
May 3, 2016 06:02 AM
Dixie61
Sep 19, 2015 06:29 AM
arnoldmilk
Sep 3, 2015 07:42 PM
