Headlight bulb replacement help STR
Old May 14, 2011 | 07:15 PM
kmrod22's Avatar
Default Headlight bulb replacement help STR
Have a 03 STR left bulb was intermittant and then finally went out. So I took forum advice bought two new bulbs so as not to have uneven lighting plus I didn't want to have to take the bumper off again. So first things first I swap left bulb. Seemed very straightforward. Finished it and turned the lights on to test. It didn't come on but right side still worked. Went ahead and swapped right bulb and now neither works. Used gloves while replacing bulbs but never touched glass anyway. Any suggestions? Is there some little detail I might have missed. I can see it being the ballast on the left but whats the odds that the right would go out like that? I'm going to test the old bulb on the right to see if I might have just gotten bad bulbs?
Old May 14, 2011 | 07:27 PM
vance580's Avatar
Try that and maybe swap the ballast also maybe you got hit with 2 things out. Then you can sort out what exactly you have thats good and what is bad.
Old May 14, 2011 | 08:04 PM
kmrod22's Avatar
Never mind I'm an idiot didn't reconnect the wire to the light connector. Do have what appears to be a bad ballast on the left side though.
Old May 14, 2011 | 08:10 PM
vance580's Avatar
That sucks sorry to hear that. Does that mean you bought the headlights for nothing then? At least you got it figured out now.
Old May 14, 2011 | 08:51 PM
kmrod22's Avatar
It was the ballast. Oh well wasn't the light bulbs but at least I won't have to worry about it again any time soon.
Old May 14, 2011 | 09:08 PM
vance580's Avatar
Yea thats good glad you figured it out before you put everything back together again.
99xk8guy
Sep 29, 2025 10:51 PM
Forcedair1
Sep 8, 2025 01:57 PM
KarimPA
Sep 3, 2015 07:32 PM
laserguy
Sep 3, 2015 02:02 PM
King Charles
Sep 3, 2015 12:40 AM
