Help
Yes I'm wanting to buy a Jag s-type from a guy he said it will not go into overdrive because of temp sensor in it is bad and leaking water.. Need to know if that's the problem or is it a transmission problem.. Please help thanks
2001 S-Type (added by GGG)
Welcome.
When you settle a tad, please do an Intro in the New Members Area.
Before ANY advice can be given, we need to know the Basics.
Year Model
Engine fitted, as in V6 or V8, or Supercharged.
Mileage on suspect car.
Then a simple ask in the S Type Tech section will get lots of answers as the time zones align.
Year Model
S-Type with overdrive. Presumably this is a 1960's model and not a modified later 1999-2009 model?
Welcome to the forum Jamie,
Thanks for confirming Model & Year.
I've moved your question from General Tech Help to S-Type forum and added the details to your first post. Members here with the same model will be able to help.
The general advice from long-time S-Type owners is to stick with the 2003-and-newer models. Many improvements were made compared to the earlier models. Read the sticky threads at the top of the S-Type forum for greater detail....
The story makes no sense. There's no water (coolant) anywhere near the transmission.
I'm not familiar with the pre-facelift 2001's, and as far as I can tell, we don't know if this is a 3.0L or 4.0L, but on the later 3.0L, there is a coolant sensor very close to the infamous "turret" that is a notorious leak point in the upper rad hose assy.
But as Mikey says, nowhere near the transmission and I'm not aware of any coolant leaks causing a shift problem.
