HELP - 4.2 S-Type Runs ROUGH when Cold
Old Dec 31, 2008 | 10:01 PM
Brutal's Avatar
Default RE: HELP - 4.2 S-Type Runs ROUGH when Cold
you know Im in Houston and we experiance alot of the same issue in the south. Different blends of gasolines that arent compatible with cold drops in temps like that. Last week 74 1 day, snow the next. But if theyve flushed the injectors, already see if theyll change the injectors, its along shot but has done wonders on a couple Jags here with similar issues
Old Jan 11, 2009 | 04:21 PM
Real_Tech's Avatar
I agree, if the injectors have already been cleaned a couple of times(assuming it was done properly with the proper chemicals) replacing them would be the next step. Not uncommon here in the cold north. Changed many but the cleaning usually works.
SD96XJ6L
Jan 12, 2022 04:30 AM
jehart49
Sep 12, 2015 05:36 PM
tberg
Sep 7, 2015 07:32 AM
pocketrocket
Sep 3, 2015 07:44 PM
Bowman
Sep 3, 2015 03:17 PM
