Help. Engine wires
Old Sep 19, 2017 | 09:22 AM
Schreatch's Avatar
Default Help. Engine wires
Hello,
I bought an Jaguar S type 2002 with 3.0 petrol engine, restyling model. The engine wires for my car has been burnt and due to this my engine is not working right anymore, two of the cylinders don't work.
Can anyone please tell me where could I order this part with all the wires to the engine block? And how this part is called?
I called everyone in my country but they have different type of this. They have two small ones instead of one big and one small like in the picture.
As I understand those don't work for me, I need exactly the same as I have already?
Old Sep 19, 2017 | 09:57 AM
abonano's Avatar
Um, that looks like a 4.2 supercharged V8. Looks like you need the engine harness. Your going to need to find a wrecker vehicle and pull yourself.
Good Luck.
Old Sep 19, 2017 | 03:28 PM
Joedotcom's Avatar
Hi
you would need both harnesses , if it were mine I would pull the connectors apart and see which wires are damaged/burnt, then pull the wires from the connectors and solder them and heat shrink them , it will save you a fortune and any auto electrician should be able to sort this for you
cheers
Joe
stremsjg
E type ( XK-E )
Oct 8, 2017 02:06 AM
