help!!!!!! jaguar only starts with wot
Old Jun 20, 2017 | 12:44 PM
mait312's Avatar
Angry help!!!!!! jaguar only starts with wot
so i recently changed my transmission my coils and water thermostat it was working fine until one night i was coming home and it just died on me out of the blue so it turns on i make it home. next morning car won't start i can hear the fuel pump so its working checked the fuses all good great battery just got it last year spark plugs are good. and when i turn it on, it only turns on with a wot, and when it turns on it splutters and then turns off after like 2 seconds and to keep it on i have to keep pressing the gas but its spluttering while its on?
Old Jun 20, 2017 | 04:50 PM
joycesjag's Avatar
Would help to know a couple of things:
-Model Year
-Engine
-Codes
Old Jun 21, 2017 | 12:07 AM
SRT's Avatar
SRT
-Model Year
-Engine
-Codes
indeed, plus what is "wot"?
water around spark plugs could cause spluttering
Old Jun 21, 2017 | 02:19 AM
Ducmon's Avatar
Read the codes
Old Jun 21, 2017 | 04:36 AM
joycesjag's Avatar
Originally Posted by SRT
what is "wot"?
Wide open throttle also here in the states known as "wfo", wide frickin open.
Old Jun 21, 2017 | 03:15 PM
SRT's Avatar
SRT
Thanks. I thought it might be some start spray of sorts.
Old Jun 21, 2017 | 03:35 PM
JagV8's Avatar
See my sig... has WOT and much more
Old Jun 21, 2017 | 03:36 PM
Mikey's Avatar
No, you're thinking of 'SYB'
http://www.nulon.com.au/products/aer...Engine_Starter
If that doesn't work, most people just mutter WTF under their breath.
Old Jun 21, 2017 | 03:47 PM
SRT's Avatar
SRT
Clicking on link:
Nulon does not look healthy!
Old Jun 21, 2017 | 04:02 PM
Mikey's Avatar
Link doesn't work because it is being edited by the bad word filter on this website
Search for 'start ya ba stard'
Old Jun 22, 2017 | 12:38 AM
SRT's Avatar
SRT
And thanks to you and JAGV8 for improving my North American linguistic experience!
Old Jun 22, 2017 | 01:03 AM
JagV8's Avatar
Not sure I can claim that as I'm from quite some way from there!
Old Jun 22, 2017 | 01:42 AM
SRT's Avatar
SRT
I see, but thanks in any case!
Old Jun 22, 2017 | 02:26 AM
JagV8's Avatar
You're welcome.
Old Jun 22, 2017 | 02:52 AM
All this input but the OP mait312 hasn't seen any of it......
Last Activity: 06-20-2017
...... 1hr 43min before the first reply in post #2 from joycesjag.
Old Jun 22, 2017 | 04:19 PM
Mikey's Avatar
Nor me. Start Ya Ba stard is from the land down under.
Where's Ken when you need him?
Old Jun 29, 2017 | 12:24 PM
mait312's Avatar
sorry guys i work night shift 6pm to 6am i get home and knock the f out after breakfast and a nice cold shower its 2002 s type 4.0 i haven't had time to read the codes i put oil in the spark plug and its turns on now but it like wants to stall and only splutters on rpm's lower than 1
Old Jun 29, 2017 | 12:29 PM
mait312's Avatar
the temp did go up but i pulled to the side before it went all the way to the red and when i slowed down to pull to the side it shut off on its own so i gave it 30 mins cranked it and i made it home so i thought it was a bore wash since my wife had turned it on and moved it. in the garage so the kids could play basketball and turned it off quick i was thinking it was that but now after putting the oil in the cylinders it turns on faster but just splutters at .5 rpm
Old Jun 29, 2017 | 01:14 PM
Ducmon's Avatar
Read the codes before you do any damage if you keep on overheating the engine then you could warp the heads.
you can buy an elm 327 from ebay or Amazon they cost peanuts and then use an program to check the car which are free but can not delete codes but you can buy this option.
Old Jun 29, 2017 | 02:19 PM
mait312's Avatar
thanks oh no car has not overheated since. just found no power to my coils only power to 2 of them
