Help me DSC Not Available
Old Jun 14, 2016 | 11:19 PM
Singto's Avatar
Default Help me DSC Not Available
i have S-type 2003 with DSC not Available light on. i have taken to mechanic and checked it, they said because of "break paddle travel sensor" so, i changed it.
The light is gone but when i start driving for a while after light come again. i turn off and on the engine light gone.
i bought it back to dealer and checked it again, i found the new fault "vacuum pressure". So i have no idea what i need to next....
Could anyone help me out about this problem??, thank you very much.
Old Jun 15, 2016 | 12:20 AM
Datsports's Avatar
buy your self an elm327 scan tool about $25 and learn how to check your fuel trims to see if it has a vacuum leak . and go from there . I'm guessing/hoping you are using a jaguar specific dealer ?
Old Jun 15, 2016 | 12:21 AM
Singto's Avatar
Yes. i went to Jaguar dealer to check the DSC
Old Jun 15, 2016 | 01:37 AM
Datsports's Avatar
could be the vacuum sensor on the brake booster faulty,
or broken/leaking booster diaphragm ,
or the brass vacuum connector oring at the manifold for the brake booster vac pipe .
also there is an oring in the swivel joint half way along the booster vac pipe
give those things a close look .
Old Jun 15, 2016 | 02:50 PM
clubairth1's Avatar
Community Influencer
Got to have a code or we are in the dark!
JaguarLover101
Apr 7, 2016 01:07 AM
Gary Newell
Apr 5, 2016 12:20 PM
shimonek
Apr 4, 2016 09:49 PM
xkeots
Mar 31, 2016 02:03 AM
Dean Kitching
Mar 30, 2016 02:53 PM
