Help please, s type grinding noise after tranny change
Hello all,I've just replaced the tranny on my 2000 S-Type 3.0 with a known good unit but I'm getting a grinding noise coming from the torque converter area,sometimes it goes but then comes back,any ideas please,could it just be low on fluid as I lost a little when replacing the oil cooler pipes? Or is it an installation error.
Thankyou
Thankyou
I would go with the trans fluid first and foremost.
You have mentioned you did loose some, so the trans will be lower than spec.
I would check it as per the book if possible.
If that is not feasable, remove the fiull plug, rear RH side of the trans case (hex plug), and add 1 ltr of fluid.
My better suggestion is to drain it, via the drain plug, then refill with fresh fluid.
I did a write up on this, and it is in the "stickies" at the top of this section.
Well that's the oil topped up but still it's making the noise,it seems to come and go which I find strange.One more point is the selector is not just lined up right as it doesn't want to go to drive from neutral,if you go from 4th to d then it's fine,I don't supppose adjustment of the cable would make any difference to the noise.
stanjag
Dec 29, 2024 08:26 PM
BrentGardner
29
Dec 16, 2024 12:13 AM
Sshenton1975
Aug 30, 2015 09:29 AM
