Hey
Old Jul 22, 2016 | 09:11 AM
Rizo's Avatar
Default Hey
Hello my 02 s type 3.0 the other day I was driving my car. When I stop the car the cooling fan was still running then I got back in the car an went to another place like for 15 minutes an stop it again an it didn't do it again. The car doesn't heat up I change the thermostat a cooling flush
Old Jul 23, 2016 | 09:01 AM
Mikey's Avatar
I've read both your posts and don't understand what you're asking.Sorry.
Old Jul 23, 2016 | 10:56 PM
Jumpin' Jag Flash's Avatar
From: Pawleys Island, SC USA (formerly from Tabernacle, NJ USA)
Agreed. Do you have a question?
Old Jul 24, 2016 | 01:44 AM
kr98664's Avatar
If I understand you correctly, you noticed the cooling fan kept running one time after shutting off the engine, but didn't do it the next time.
It's normal for the cooling fan to run after shutdown if the coolant temp was above a certain threshold. That would explain why it didn't do it the next time, as the coolant probably wasn't quite as hot.
On my '02 V6, the cooling fan rarely stays on after shutdown. It has to have been a very hot day with slow traffic for the coolant to reach that temp.
Please keep in mind the temp gauge is deliberately misleading. I forget the exact numbers, but there's a range of about 40 degrees F where the needle stays centered. Above that band, the needle will start to climb, but as long as the coolant temp is within that band, you'd never know by watching the needle if the actual coolant temp is at the top or bottom or anywhere in between.
I'd make sure the cooling system is filled to the proper level and just keep an eye on it. On my car, it's rare for the fan to run after shutdown, but it does happen on occasion and is no cause for alarm as long as the temp gauge stays in the normal centered position. Maybe some others can confirm how often their fans run after shutdown.
xjsman89
Aug 26, 2016 05:12 PM
Slow
Apr 10, 2016 04:10 AM
Jan 3, 2007 09:06 PM
Dec 11, 2006 01:25 AM
Nov 30, 2006 11:15 AM
