High Calulated Load and (-)LTFT
Old Jul 15, 2011 | 07:11 AM
camclean1's Avatar
Default High Calulated Load and (-)LTFT
I've noticed a few other post that vaguely talk about CLV and STFT/LTFT and I'm wondering if someone could shed just a little bit of light for me. I have a 2000 S Type 3.0 and my Calculated Load Value is 62% and my LTFT for both banks are around -25%. I've seen conflicting info about what's good or not good when it comes to both so I'm a little confused. Oh I do have 1 code on the MIL and its a P1388 (even after dealer reflash). Can someone enlighten me on what the numbers should be in an acceptable range? Thanks
Old Jul 15, 2011 | 09:00 AM
JagV8's Avatar
I don't normally look at CLV but in any case ignore it until those trims are near 0 (say within +/- 5%).
At what rpm do you see -25%? It means the PCM is seeing the exhaust as so rich that it's subtracting the largest amount of fuel it's willing to do. I don't understand why you don't have rich codes (almost everyone else sees lean codes LOL).
The good news is you probably don't have an air leak.
Ideally you'd get engine hot (warmed up), watch both banks are CL (closed loop) and then look at the trims at idle and about 2500rpm.
If they stay that kind of number, check O2 sensor signals (for your car, voltages) are sane. For HO2S to work they have to be hot (that's HOT) so you may need to drive then park and measure or rev for a minute and measure. The upstream ones should constantly swing from about 0.2V to about 0.8V. The downstream should not swing much if at all.
You need to check the O2s because if they're not working right then the whole engine is out of proper control and you may as well ignore all values (except for diagnosing what's wrong).
If O2s are OK, your MAF may well be reporting the wrong readings but see what others say unless you have access to another free or cheaply.
P1388 is covered elsewhere but reflashing will only fix it if it's being falsely flagged. Sounds like yours is being flagged (non-falsely). The codes PDF (see FAQs, JTIS or Gus's site) will have details I expect.
edit: you can't read many data values per second so only log the O2s (maybe rpm as well) or you won't get a feel for what the volts are doing
Old Jul 15, 2011 | 11:13 AM
camclean1's Avatar
Here's my latest readout:
2000 Jaguar S-type Engine v6 3.0
Mileage
145000
Stored DTCs
DTC Description
P1388 Variable camshaft timing over retarded, bank 2
Pending DTCs
DTC Description
No DTCs present on code reader
MIL Status
MIL ON
Comprehensive Component Monitor
CCM Complete
Misfire Monitor
MIS Complete
Fuel System Monitor
FUE Complete
Oxygen Sensor Monitor
O2S Complete
Oxygen Sensor Heater Monitor
HTR Complete
Catalyst Monitor
CAT Not Complete
Heated Catalyst Monitor
HCA Not Supported
EGR System Monitor
EGR Complete
EVAP System Monitor
EVA Not Complete
Secondary Air System Monitor
AIR Not Supported
Air Conditioning (A/C) Refrigerant Monitor
ACR Not Supported
Freeze Frame
Parameter Description Value DTC for which Freeze Frame was Stored
P1388
Fuel System 1 Status
Closed Loop
Fuel System 2 Status
Not Supported
Calculated LOAD Value
62.75 %
Engine Coolant Temp
203.00 °F
Short Term Fuel Trim -Bank 1
10.94 %
Long Term Fuel Trim -Bank 1
-25.00 %
Short Term Fuel Trim -Bank 2
4.69 %
Long Term Fuel Trim -Bank 2
-26.56 %
Fuel Rail Pressure
39.57 psi
Engine RPM
2327 rpm
Vehicle Speed Sensor
14.91 mph
Report#
Date: 7-15-2011
Old Jul 15, 2011 | 12:16 PM
JagV8's Avatar
You don't have P1111 so I suppose you've cleared the codes.
Something's stopping the Cat Monitor.
Back to looking at HO2S voltages.......
Old Jul 15, 2011 | 01:06 PM
camclean1's Avatar
I never had P1111 show up but I have had P0133 P0153 recently. Sometimes they will show up for awhile and disappear. I have no idea what circuit slow response means though. I guess I'll try looking at the voltages this weekend
Old Jul 15, 2011 | 01:48 PM
JagV8's Avatar
Read the codes PDF as I said above. Lots of details in it.
Also check those voltages, preferably as waveforms (graphs) so you can really see them.
This is starting to look like awkward DIY as you're going to be trying to figure if the O2s are OK or not, if the wiring is OK or not, if the .... well, you get the idea. Don't skimp on the reading if you're going to DIY.
hoodun
Nov 20, 2022 02:35 PM
GGabriel
Nov 22, 2018 03:53 AM
davidladewig
Oct 15, 2015 03:18 PM
driver safz
Sep 26, 2015 06:01 AM
Jandreu
Sep 20, 2015 08:20 AM
