How do you adjust a gear shift cable for a 2002 Jaguar S-type automatic?
Old Sep 11, 2018 | 10:27 PM
baxtersuber's Avatar
Default How do you adjust a gear shift cable for a 2002 Jaguar S-type automatic?
adjusting gear shift cable on 2002 Jaguar S-type automatic
Old Sep 11, 2018 | 10:44 PM
NBCat's Avatar
Which engine is fitted to your X200?
Refer to the Workshop Manual, if you don't have the Workshop Manual, you can download it here:
https://www.dropbox.com/s/aq3872pbu5...kshop.pdf?dl=0
Refer to section 307-05.
Before tampering with the gearbox or other components, check to see if the two 8mm bolts securing the cable to the gearbox are in place and tight. If they fall out the vehicle will not shift properly. These bolts should be checked at each oil change if the vehicle is fitted with the ZF 6HP26 gearbox.
jagger
Oct 1, 2022 09:05 AM
Dell Gailey
Feb 12, 2019 01:02 PM
kainy
Sep 5, 2018 11:21 PM
iownme
Aug 22, 2018 07:49 PM
Cfl039
Aug 6, 2018 05:25 AM
