How to get key code
Old Sep 21, 2020 | 06:32 PM
Paulie710's Avatar
Default How to get key code
I only have one key to my 07 S type How do I get the key code to have a key made Is the key code written or stamped anywhere in the car
Old Sep 21, 2020 | 10:07 PM
xalty's Avatar
Decoding a 6 cut tibbe key is pretty easy and with some practice you can break into a transit connect in about 30 seconds or less with the pick tool.
https://www.google.com/amp/s/www.ukb...r-how-it-works
https://www.ebay.com/itm/283228094313
Call around till you find a dealer that has a cutting machine and then they’ll charge 35ish to cut and around 200 to program it. Mobile locksmiths can also do it but prices are about the same.
Old Sep 22, 2020 | 02:20 AM
JagV8's Avatar
Depending on country locksmith can be much cheaper.
Old Sep 22, 2020 | 05:47 AM
kr98664's Avatar
Isn't the required programming such that you have to have all keys present during the process? In other words, if you add a key, the car's security code is reset and any existing keys won't work if they weren't reprogrammed at the same time. Or was that just for fobs, not keys?
Old Sep 22, 2020 | 10:04 AM
M-e-l-l-o-w's Avatar
There are three parts to the s-type 'keys'.
The actual tibbe key blade. That is the easy part!
The transponder in the handle of the tibbe key.
The separate remote key fob.
As far as I know both these last two require re-programming of the car.
I am not sure if it can be done with anything other than the Jaguar SDD software.
Yes, you do need all the keys to add a new one.
Mellow
Old Sep 25, 2020 | 01:21 PM
clubairth1's Avatar
Community Influencer
Yes but get the blank cut first. Then do the programming.
I paid $10 to get each blank cut at the dealer. But he did require I bring the title down proving ownership BEFORE
he would even consider cutting the blank. An independent lock smith might not require this.
Sovejag13190
Sep 22, 2018 05:46 AM
Cee Jay
Nov 2, 2017 05:09 PM
kstevusa
Aug 4, 2015 03:21 PM
mehul0623
US Western
Dec 23, 2014 07:50 PM
estunum
XJ40 ( XJ81 )
Apr 29, 2009 09:55 PM
