How to remove fender mounted blinkers.
Old May 7, 2008 | 07:45 PM
T.C.'s Avatar
Default How to remove fender mounted blinkers.
How on earth do you remove the fender mounted blinkers.
I want to remove them to shoot em with nite-shades.
I have allready blacked out my jag for the most part but now i need to do those and the rear tail lights. I love a properly murked out car.
Thanks!
Old May 7, 2008 | 08:36 PM
jag_genius's Avatar
Default RE: How to remove fender mounted blinkers.
to do it properly.. just stick your hand in from the fender and pop it out
Old May 8, 2008 | 07:44 PM
T.C.'s Avatar
from where in the fender?
Should I remove the fender liner? then go that route?
Thanks!
Old May 15, 2008 | 02:23 PM
millben's Avatar
I don't know about removing the liner. but I just removed my left rear marker to replace the bulb and I was able to do so by pushing up on the lens and then prying the bottom out with a flat plastic butter knife. I suspect a wood popcicle stick would also work. You just need something that won't harm the lens but will be strong enough to pop out the entire unit. There are springs at the top and retaining lips at the bottom.
Mike
Old May 15, 2008 | 09:25 PM
T.C.'s Avatar
the ones on the corners i have removed and blacked out allready. I'm speaking about the signal markers that are located behind the front wheel in the front fenders. I don't want to tear the entire fender liner out and find out theres an easier way.
thanks.
BTW: attached is a pic of my S-type
[IMG]local://upfiles/3640/F862C57A3C0646AC8A12B468E24E55C3.jpg[/IMG]
Matei Dima
Oct 8, 2015 11:45 AM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
Marque
Sep 14, 2015 11:17 AM
1964Daimler
Sep 9, 2015 11:28 AM
SouthernGypsy
Sep 3, 2015 10:54 AM
