HVAC Interior sensors
Old 03-02-2010, 08:40 PM
cleveland's Avatar
According to my owners manual for a 2003 3.0 S type sport, there is a temperature sensor behind the plastic grill just above the ignition key, and there is a solar sensor in the middle of the dash at the base of the windshield. This plastic grill pots out easily. I have read to there is also a sensor just above the accelerator pedal that is attached to a HVAC control box but have not been able to find this sensor, although I have not taken apart the dash. I cleaned both sensors with mass air flow sensor cleaner which is suppose to not attack plastics. I was having a problem of inconsistent heating and cooling, and this cleaning seems to have fixed the problem. I also pulled the fuses for the HVAC system and disconnected the battery for a bit, and this may have served as a "reset" of the HVAC.
Old 03-03-2010, 06:52 AM
Mafioso's Avatar
I found the sensor near the pedal, in the evap box ni clue how to remove it. Is the solar sensor hvac related or is it for the auto headlights?
Old 03-03-2010, 11:24 AM
cleveland's Avatar
I found the reference to the solar sensor on the dash in the climate control section of the owners manual, so assume that it is related to climate control.
Old 03-03-2010, 11:55 AM
Mafioso's Avatar
I'll have to see how I can remove clean that sensor then. Thank you
Old 03-04-2010, 10:00 AM
Mafioso's Avatar
Anyone know how to remove the panel that golds the solar sensor and the twillight sensor? I tried last night and ended up cracking it on one spot
Old 03-04-2010, 06:17 PM
Mafioso's Avatar
finally got the solar sensor removed and inspected so far so good. I still haven't been able to remove the sensors from the evap box. I think I'm getting closer to a fix. I have a little bit of heat for about 5 minutes when I first start the car. Still no ac
Old 03-24-2010, 12:18 PM
Mafioso's Avatar
So an update.. The dccv is bad although it's new, replaced it again and all is well now
Jumpin' Jag Flash (07-24-2017)
  #28
Old 03-24-2010, 12:22 PM
Jon89's Avatar
Received 4,299 Likes on 2,824 Posts
A faulty DCCV right out of the box, huh? Sure hope your chosen source replaced it for you at no cost and apologized for your inconvenience....
Old 03-24-2010, 02:39 PM
mep's Avatar
mep
mep is offline
There was mention of factory navigation on here....what if the car HAD navigation but all was since taken out? Is there another module or something that has to be added in place of what was taken out? I ask this because my heat doesn't seem hot enough either.
  #30
Old 03-24-2010, 06:21 PM
clubairth1's Avatar
Received 2,269 Likes on 1,787 Posts
Thanks for posting back!! That's the first new DCCV that was bad out of the box. I wonder if any of the factory techs have seen this? My DCCV just started seeping and I will be replacing it in a couple of weeks. Hope I don't get a bad one from Jaguar!!
  #31
Old 03-24-2010, 08:40 PM
Mafioso's Avatar
Yea it's all fixed under the shops warranty. It was really cold here so I had the idea of unplugging the dccv which according to the forum should give me full heat and I got zilch. So I took it back to the shop. Had them order a new one after raising a little hell. And it was replaced. Could it be possible he took a cheap way out and got a rebuilt one?
  #32
Old 07-09-2010, 03:17 AM
pdog2000's Avatar
so how did you get the solar sensor out? do i just pull up the panel that holds the solar sensor? does it just pull right out?
  #33
Old 07-09-2010, 12:57 PM
tbird6's Avatar
I don't think a rebuilt DCCV is available but with all the failures on many different cars it would seem like a good idea!!
42Ajd
12-30-2015 09:45 AM
John Fox
09-12-2015 12:20 PM
KarimPA
09-12-2015 08:15 AM
KarimPA
09-03-2015 07:32 PM
King Charles
09-03-2015 12:40 AM
Quick Reply: HVAC Interior sensors
