I am losing my mind! - My update on the 2000 4.0 V8 S-Type
Old Feb 27, 2021 | 08:18 PM
jya's Avatar
jya
Originally Posted by kr98664
Step back from the ledge! Don't jump!
Unless you are a climate change researcher, don't aim for a predetermined conclusion. Go where the troubleshooting actually leads you, not where you fear it might go.
The conclusion you have reached is HIGHLY unlikely. To have oil leak out like you're thinking, you'd have to have two major issues active at one time. You'd have to have severely worn piston rings and/or valve seals to dump that much oil into the exhaust. And then you'd have to simultaneously have a major exhaust leak to let that oil escape.
Now it does appear you have an exhaust leak. But I'd be willing to bet your reputation that the oil you're seeing is the remnant of what you have previously added to the cylinders. To fully clear it out, It might take some hard driving for 50-100 miles. (If using the metric system, that 50-100 miles) If you've only been running at idle or putzing around the neighborhood, you've still got plenty of excess oil in there. Don't scare yourself of some major internal damage.
Some steps to take:
Fix the exhaust leak. This can affect what the O2 sensor sees and contribute to rough running.
Review all previous vacuum leaks that were repaired. If you insist there are no leaks because you replaced those suspect gaskets, I shall force you to watch "Beaches: The Director's Cut" until you beg for mercy.
https://m.youtube.com/watch?v=G59ivoXtmW4
There are no guarantees a new gasket is sealing properly. Maybe you've got a warped casting or a gasket didn't fit properly. Retest to be sure.
Consider replacing the coils. This has been previously discussed.
Check the fuel pressure at the injector rail with a mechanical gauge. This was suggested in your other thread, with no mention that it was accomplished. Do not rely solely on the scanner reading. The poor computer will happily regulate fuel pump output inaccurately to match a bad sensor and never set a fault code.
That's a very good and hilarious post! The threat of watching 'Beaches' is enough to get anyone to move into action!
Old Feb 27, 2021 | 09:42 PM
kr98664's Avatar
If that's not scary enough, there's always Yentl:
Old Feb 27, 2021 | 09:45 PM
jya's Avatar
jya
Don't make me laugh Karl!
This is a fate worse than death!
That's too funny!
Old Mar 1, 2021 | 10:40 PM
davidladewig's Avatar
Yentl? That would make the wheels fall off a Jaguar. The windows would explode. The gas tank would crumble. the airbags would deploy to stop anyone from watching that horror flick!
Old Mar 2, 2021 | 07:20 AM
The_Portuguese's Avatar
kr98664, I hereby swear I already ordered all the parts needed to do the compression test, the fuel pump test and got the 8 new coils. Not only that, I will take the car for a hard drive as well and follow all other instructions you mentioned. I shall have updates on Thursday.
Now, with all that said and promised, please, deliver us from any other movie/torture recommendations. After this point on I will consider it as gratuitous sadism.
Old Mar 2, 2021 | 08:12 AM
S-Type Owner's Avatar
Oy vey, davidladewig...!!
Old Mar 2, 2021 | 04:48 PM
kr98664's Avatar
I wouldn't dare. Besides, if the threat of Beaches AND Yentl didn't work, the next phase would be I move into your guest room. I shall PM you a list of my dietary needs. Does your house have good plumbing? Quiet time between 8pm and midnight please, as I need no distractions during my accordion practice time.
Old Mar 3, 2021 | 04:58 PM
  #28
With only 72,000 miles, I think you mostly have a little bit of neglect from sitting and nothing all that major. Once you get your coils on, put some heavy cleaner in your tank and go drive it at hwy speed for 4 or 5 hours. 2.5 hrs out, have lunch and 2.5 hrs back. See if that helps lots of things. Gas mileage on the car is about 14.5-16.5 mpg in town. Out on the hwy, you should be at 23.5 mpg @ 70 mph. That's what I get.
XTyperProFiler
Nov 18, 2018 02:46 PM
BeckBeck
XJ40 ( XJ81 )
Feb 6, 2018 08:33 AM
Nookpad
Jan 10, 2018 04:47 AM
Jagst02
May 16, 2016 01:02 PM
jaguarguy13
XJ40 ( XJ81 )
Dec 2, 2015 10:18 PM
